Old 10-18-2009, 05:45 PM
ger21's Avatar
Can anyone change my SMD resistors?
I have an instant electric water heater, and fried some resistors on the control board. I had a spare board, but fried them both. I think I need to replace the triacs??, as there are really no other parts in it. I'd like to see if changing these resistors will get me back to full power, as right now, it's only working at half power and it's just hot enough to shower. The coming cold weather will drop the water temp, and it won't be hot enough.
I know that the two (R3, R5) are 1K ohm and it looks like R1 may be bad as well. I think it's 10K ohm. When I try to measure it, I get a correct reading for a half second then it starts jumping around.
Thanks.
Name:	Circuit Board 003.jpg‎
Old 10-18-2009, 10:23 PM
ViperTX is on a distinguished road
Gerry,
If you have a soldering iron and some solder wick you can change them yourself....wick some of the solder...and using a pair of tweezers lift one end of the resistor up....if you have a friend and another soldering iron you can accomplish this task much quicker.
Unless you have some sort of active control circuitry....you probably just have a diac which is used to trigger the triac....if the triacs are operating at all (indication by the half power mode) they are not the problem.
Paul
Old 10-18-2009, 10:50 PM
Al_The_Man's Avatar
They appear to be MOC3063? if so these are triac opto's and the resistor is connected to pin 4 which is the output side to a external triac, I would imagine.
You may also have a open external triac.
http://www.fairchildsemi.com/ds/MO/MOC3063-M.pdf
In a pinch you could replace the SMD with miniature axial resistors, although it won't be pretty!
Old 10-19-2009, 08:07 AM
ger21's Avatar
Yes, that's what I was talking about. There are 4 that turn on the heating elements. I believe those are what caused the resistors to go bad.
Yes, I thought about just using regular resistors, as those SMD's are so small I can barely see them
Old 10-19-2009, 08:49 AM
Al_The_Man's Avatar
If the resistors have also been stressed then you may also have to replace the opto's as they only take 60ma on the output triac, and the resistors are in series with them.
If you need to test the outboard Triacs, you should be able to turn them on by connecting a resistor of the same value as the overheated ones placed across the two output terminals.
They will be turned full on however.
Old 10-19-2009, 08:25 PM
Gerry, how many heating coils does you heater have? I would say that you would have one triac per coil in which case you should be able to tell which heating element is not turned on which would point to the triac or the control circuitry.
Thanks,
Paul
Old 10-19-2009, 08:48 PM
ger21's Avatar
Edit: I already know that at least the resistors are bad.
4 coils
Yes, there is one per coil. Originally, one Triac burned up, and they sent me a new one with the new board. Although I think the board was still good.
A few months ago, I was seeing similar issues to when it burned up before. The unit uses a flow switch to turn on and off. What started to happen, was it didn't shut off when the water stopped. You could hear the water stat to boil until the thermal overload tripped. (Each coil has one). One of the triacs shows signs of getting very hot. (brown wires). They're only about $9 each, so I was going to replace them all and see if it works if I swap out the resistors. I was poking around in there, and when I turned up the temperature (pot connected to the board), I saw the resistors burn with a quick bright flash. Changed the board, and saw it happen again. It's been running for a few months now at about 50% power or less. I'm a little unsure how to check the triac, as the terminals have heat shrink covering most of them, and I was afraid of the probes touching and having 50 amps of 220 at my fingertips. Actually, there are 2 50 amp breakers, so 50 amps for two elements.
I bought the heater 8 years ago, and it had a lifetime warranty. Until they went out of business. A new one is $800
Do you guys think that replacing the resistors, optos, and triacs should do it?
Old 10-19-2009, 09:08 PM
Al_The_Man's Avatar
I would also investigate fitting a higher rated triac and a decent heat sink, what is the part number?
If you change the resistors, you should not damage anything by testing to see if the opto's are OK.
If they are open, you will have no control, if they are shorted it will just turn on the heater triac with no control.
It sounds like they may not be phase angle controlled for heat adjustment, the unit probably switches each heater full on in turn.
Old 10-19-2009, 09:19 PM
ger21's Avatar
I'll open it tomorrow and check the #, and post a pic. They are mounted to the cold water inlet pipe, so they get plenty of cooling.
Old 10-19-2009, 09:25 PM
Al_The_Man's Avatar
I am surprised they they would heat up if they are water cooled?
Especially with a resistive load.
Old 10-20-2009, 06:58 PM
ger21's Avatar
Al, they are Q6040J7.
These are the right ones, right?
http://www.mouser.com/ProductDetail/...J%252bQNeZk%3d
Name:	heater sm001.jpg‎
ID:	91596   Click image for larger version
Name:	heater sm003.jpg‎
Old 10-20-2009, 07:50 PM
Al_The_Man's Avatar
That looks like the ones.
If you want to test them you can usually use a 12v/24vac transformer and connect the triac in series with a lamp, and use a 75/150ohm resistor from MT2 to gate to turn it on and off.
Maybe also check the heater resistance to make sure they are all the same.
Problem- Power resistors,Pls help sa1 General Electronics Discussion 5 08-17-2009 01:11 PM
Help with resistors en capasitors DimiOrla Stepper Motors and Drives 8 04-13-2007 10:19 AM
Sensing Resistors vs Current limiting Resistors whitney Hobbycnc (Products) 3 11-05-2006 11:29 PM
braking resistors. najnielkp Servo Drives 2 07-07-2006 11:03 AM
Resistors!! How hot? southernexplore General Electronics Discussion 4 11-19-2005 09:32 AM
