Old 03-11-2005, 04:23 PM
murphy625 is on a distinguished road
Using a large drive on small motor?
I've been using a 4KW drive on a 1.3KW motor for driving a brushless servo motor. I have another drive here that I was planning on using as my spare but it is much larger.. now I am having second thoughts.
What problems could occur by using a much larger drive as a spare replacement ? I have an identical drive to the 4KW but its rated for 7.5KW. There are settings within the drive that allow you to limit the max power output from 0-100% for both normal amp operation and the max amps /sec operations.
But what I am wondering is if there will be any side-effects from using a drive that is so much larger. Could I run into tuning problems or anything else?
Thanks,
Murphy
Mill drive motor died. devinchi Shopmaster/Shoptask 12 05-14-2006 12:47 AM
What motor drive for an arm? nervis1 RC Robotics & Autonomous Robots 9 12-16-2005 02:30 PM
340 or 320 with large motor johnd Gecko Drives 1 05-11-2005 03:07 PM
Motor torque calcs with Xylotex drive butwillitwork Xylotex 4 03-18-2005 02:44 PM
Good DC motor and drive JRoque General Electronics Discussion 11 01-02-2005 09:38 PM
