I need some connectors for connecting my motors to the drives, what else is out their instead of Molex connectors that is better? I'd like 8 pins and need them to be panel mount.
__________________ Thank You, Paul G Site Owner-Webmaster- Administrator www.rfqwork.com www.cnczone.com www.welderzone.com |
| OH I should have added they need to handle 8 amps, VGA and serials are only good for 3 amps, I believe.
| Molex I have used and am using, and they don't hold up very well, I need connectors that can be plugged and un-plugged many times (I'm not going into why), I just want to see what my other options are, I'm using serial connectors which are OK for lower amps.
| Are you sure you need 8A? That's going to be hard to find in an 8 pin connector without spending $$$ I this for steppers or Servos? If you are talking 8 wire steppers then you can use 6 pin connectors and just wire the two center taps together in the plug housing. You can find 6 pin connectors with a 7A rating or higher pretty easy.
__________________ Nathan Last edited by anoel; 03-11-2005 at 12:17 PM. |
| Have you looked at the Amp/Tyco CPC series? They claim up to 25amps (although that seems a bit high to me). They are reasonably priced an you can get inline and bulkhead style. example for a basic bulkhead and inline connector 206705-3 & 206705-1 9 contacts is $4.00 & $3.30 each plus you need the pins which you can solder or crimp without buying the special tool. There are alot of combinations in this series. Al
#10
| Here are some Mouser Part Numbers for 8 Contact Rectangular Power Connectors rated at 10A. 538-38331-5608 @ $3.81 538-38330-0508 @ $2.11 Will require a sqare hole and not the prettiest things. But should be plenty robust and practical.
#11
| These are three pin, rated for 15 amps at 125 volts! I know they don't have all the pins you want, but for motor power I think they are awesome! They have a positive locking too they SNAP into the socket. Check em out here: http://www.jameco.com/webapp/wcs/sto...tegoryId=11469 Bob |
#12
| CNCadmin, Well I think you need to decide if the connectors "don't hold" means that the body falls apart, dislodges from it's panel, or ??....also "don't hold" could mean that the contacts fail after many insertions. Each scenario results in a slightly different solution, if it's connector reliability (resulting from the contacts wearing out) then you need to find a connector that has low or reduced insertion force. If your connectors are dislodging from their mounting then you'll need to determine if you are using the proper style connector (panel mount with tabs, with screws, with clips, etc.). Just think of what you would tell a connector sales person about what you need. Tighten down your specifications! |
| AMP Connector for Bridgeport Boss 8? | Bill Gillen | Bridgeport and Hardinge Mills | 2 | 05-06-2005 11:19 PM |
| DB25 connector | TigerPilot | Stepper Motors and Drives | 2 | 03-20-2005 04:06 PM |
| 25 pin connector | polyhedron12 | General Electronics Discussion | 4 | 02-23-2005 04:40 PM |
| Can I use J8 Connector for Xylotex | Sanghera | Xylotex | 0 | 10-09-2004 09:56 PM |
| Help find terminal connector type for this stepper | Konstantin | General Electronics Discussion | 3 | 10-09-2004 01:34 PM |
