| Yes it is step and direction. It has an internal oscillator that you can hook up the step input to and the drive works fine. I can't however determine the voltage I don't have a scope. I am trying to run it from Mach2, with a soundlogid reakkout board.=b step and direction 5V setting on the step. I have tested the PC side and the sound logic breakout board with another (PacSci) drive that takes a 5V step input and it works fine. So I know the setup is good. I just cant get the SD3 to respond to the 5V. I have a feeling that it needs 12v on the input and the drive is taking that to 5V TLL level on the board. I am just not sure. Unfortunately I am not an electrical engineer, and can't get to board level with my current understanding. The book states the indexer is sending 12V. I dont have the indexer board, and can't find one K |
| Hi Ken, Maybe I can help. I use the Parker Digiplan PK2 drives on my mini-lathe. They need a 12v signal to work. You can take the 5v up to 12v with a 3.3k resistor and a 2N3904 Transistor on each line. I attached a diagram from my manual, hope it shows up. I can't say that this will work for yours, but it sounds like it will. Tim |
| You can use one of the charge pump RS-232 trancievers, this will get you to ~10 volts but not 12 The easiest way would be a couple of BJTs and a 12 volt source. Aaron |
| What servo drives use resolver inputs? | murphy625 | Servo Motors and Drives | 3 | 03-15-2005 12:28 PM |
| newbie AC Servo question | GalaticDan | Servo Motors and Drives | 3 | 10-30-2004 11:25 PM |
| problems with tuning of Rutex drives | FrankdB | Servo Drives | 2 | 06-21-2004 03:16 AM |
| Rutex Drives | mikburts | Servo Drives | 0 | 05-01-2004 07:55 AM |
| steppers or servo drives | mmjpotter | Gecko Drives | 14 | 03-30-2004 02:56 PM |
