Old 09-18-2009, 05:23 PM
stk2008 is on a distinguished road
oh no only my y axis keeps stalling
Hi all ive finaly done it all be it less limit switches so i have only joged very very carfully.
i have an issue with only the y axis it keeps stalling all the others work great not one prob but just the y axis.
ive not done a hell of a lot as im tired and just got it to this point but realy want to hear a few reasons as to why they do it.
all of my motors are the same so is the drivers there for they are all tuned to the same in mach 3....cant remember the settings will post during weekend.
im just confused as its only that one axis that is doing it.
Old 09-18-2009, 06:02 PM
ger21's Avatar
Could be that there's slight misalignment. Could be that the nut is tighter. Could be that the screw is bent slightly. Could be resonance. Could need lubrication.
Post a pic of your machine, and what drives, power supply, motors, screws, and nuts your using. What are your velocity and accel settings? What speed does it stall at?
Old 09-18-2009, 06:07 PM
hi cheers for input
yes the trapezoidel spindle is a bit bent but i can turn it from one end to the other with me hand tho and these are very big motors so even a little stiffness shouldent stop these buggers.
you say vibration can do this ummmm ok will look into that as they do vibrate a fair bit but then so do all the other axis and there fine.
heres me other post im on wrong pc i have no pics at moment
http://www.cnczone.com/forums/showthread.php?t=89586
http://www.cnczone.com/forums/showthread.php?t=68626
edit sorry and motors
http://www.motioncontrolproducts.com...per-motors.pdf
im not sure how smooth or what noise motors should make etc mine do feel a little grindy when i hold them but they see to run ok?.
cheers
Old 09-19-2009, 02:31 PM
pminmo's Avatar
pminmo is on a distinguished road
Is the stall when moving it slowly or rapidly?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 09-19-2009, 02:57 PM
hi i will be honest ive not done much testing as i was on it from 6:00am till last night and i was tired ive been on it none stop at those times for about a week now hehe.
ive only tested it on rapids and thats when it does it not every time but most
Old 09-19-2009, 04:06 PM
pminmo's Avatar
what is the screw pitch? how fast is the rapid?
Old 09-19-2009, 04:19 PM
hi again ummm I think its single start 5 pitch trapezoidel spindle.
but why does it only do it on that one axis
Old 09-20-2009, 04:42 AM
hi again ive just swapped another motor off s different axis and tryed that it works good not one stall so ive checked me wireing thats ok to doh.
edit
ok ive got some weird problems going on here.
z axis at 100% rapid speed works perfect then if i change it to say 75% it starts then just stops making a noise but if i bump it back up to 80% rapid feed its as smooth a silk again?.
same goes for all the others axis not at 75% tho they are all different could it be vibration from motors?
me settings are motor tuning
steps per = 1600
velocity = 600
acc = 200
step pulse = 1 (as per instructions from diagram)
dir pulse = 5 ( as per instructions from diagram)
i do seem to have vibration at some speeds then at others its ok again?.
my psu motion control x2 42v 280w
drivers
motion control msd542
motors motion control fl86s (huge buggers)
i may try and change me kernal speed and allso change the power supply as its not that good
please advise on what i could do to fix this
cheers in advance.
Old 09-20-2009, 09:47 AM
ok ive been doing yet more testing and im so convinced it vibration making the motors stop is this possible?.
as if i take the motor out of the cnc and place it on the bench it works perfectly but if i put it back in the machine i hear whats like a vibration noise just befor it stops.
im going to get some rubber washers and place them between the mount nd motor see if that helps but befor i do is vibration a possible cause or is the noise im heraing to do with the motor not working correctly any ways?.
Old 09-20-2009, 12:20 PM
ger21's Avatar
Read the stepper motor damper thread. I made some dampers and my machine become perfectly smooth at all speeds.
  #11   Ban this user!
Old 09-20-2009, 01:57 PM
HI THANKS FOR REPLY YES I DID SEE YOUR THREAD BUT IS IT FULLY POSSIBLE TO HAVE VIBRATION STOP THE MOTORS?.
sorry about all caps just spotted it sorry.
  #12   Ban this user!
Old 09-20-2009, 03:00 PM
pminmo's Avatar
Sounds like your motors are resonating. You say your pitch is 5, and your steps per is 1600. If you haven't set your driver to a microstep size you need too. Can you post your actual screw pitch and your driver step size selection?
HAAS TL-3W stalling ghafer Haas Lathes 11 07-07-2009 11:42 AM
Stalling steppers sp1nm0nkey Stepper Motors and Drives 3 07-01-2009 09:37 AM
Need Help!- X Axis Stalling?? (no movement.) tsquint1138 Bridgeport and Hardinge Mills 5 06-04-2009 09:06 AM
Newbie- Z Axis stalling when plunging slot drill Adethelathe General Metalwork Discussion 8 05-26-2009 10:27 PM
Y axis stalling/hanging up tdnp DIY-CNC Router Table Machines 7 12-15-2007 02:13 PM
