Old 09-14-2009, 08:45 PM
oxford's Avatar
oxford is on a distinguished road
Magnetic contacts and AC drives
I was looking at Ac drives and the their peripheral electronics.
What role do the magnetic contacts play?
Do you need a emf line filter?
Is it ok to step up 110V to 220V to meet drive voltage requirements?
Old 09-14-2009, 09:08 PM
Al_The_Man's Avatar
Cool 10,000th post
Not quite sure of the questions, but for VFD's often the manufacturer will recommend three phase chokes or reactors, in some cases I have fitted them on the input and output.
Most hobbiests do not bother it seems.
Magnetic contactors? These are uses to disconnect three phase power to the VFD input, never between VFD and motor.
They are usually picked up when the E-stop is released to put the VFD in the ready condition.
There is usually nothing wrong with raising the voltage by transformer for example, if the VFD warrants it, keep in mind the 120v current will be double the 240v current draw.
Old 09-14-2009, 09:49 PM
oxford's Avatar
example of question
I think that answers the question.
Here is an image of the wiring of a drive that I was talking about
Old 10-26-2009, 04:25 PM
oxford's Avatar
Anyone know of a good source for magnetic contacts?
Old 10-26-2009, 04:58 PM
Al_The_Man's Avatar
You can pick up Telemecanique contactors off ebay, the DIN style DIN rail mount are nice and compact.
Other makes are Allen-Bradley and Square D etc.
Old 11-02-2009, 09:42 PM
oxford's Avatar
How important is it for the contactors to have surge suppressors?
Old 11-02-2009, 10:22 PM
Al_The_Man's Avatar
If you mean RC snubbers across the coil, I would recommend it for AC coils and reverse diode for DC coils.
Old 11-04-2009, 08:56 PM
oxford's Avatar
Are there any type of Contactors that are not compatible with a RC snubber?
Old 11-04-2009, 10:01 PM
Al_The_Man's Avatar
An RC snubber goes across any contactor coil if it is AC, A DC coil takes a reverse EMF diode.
Old 11-06-2009, 08:36 PM
oxford's Avatar
Is the RC snubber type determined by ac voltage?
Old 11-06-2009, 08:48 PM
Al_The_Man's Avatar
Previous link.
http://cnczone.com/forums/showthread...hlight=snubber
The capacitor max voltage rating has to exceed the applied voltage.
The values can change according to the energy stored in the device.
The one shown is good for the average solenoid and most DIN style 3 ph contactors.
  #12   Ban this user!
Old 02-09-2010, 10:22 PM
oxford's Avatar
In the AC servo drive set up, there is a Molded Case Circuit Breaker before the Magnetic Contact. Is it possible to just use the right rated circuit breaker that can be found for cheap at the hardware store... The kind you find in your basement fuse box?
Camaster Contacts???????? SamLS Camaster 18 10-30-2008 07:26 AM
Contacts in Central California bothunter Mentors & Apprentice Locator 3 05-03-2008 01:48 PM
IH Contacts IHCNC Industrial Hobbies (Support forum) 0 04-17-2008 01:25 PM
15M control, PLC diagnostic F and G contacts??? steve-o Fanuc 5 01-07-2006 06:55 AM
Quad SPDT Relay Board - 15A 250VAC Contacts winfordeng Product Announcements & Manufacturer News 0 07-26-2005 08:08 AM
