Old 09-02-2009, 06:36 PM
Senna's Avatar
Senna is on a distinguished road
Controller Schematic... First Attempt
I'm at the point in my build (http://www.cnczone.com/forums/showthread.php?t=65393) where the mechanical side of the construction is almost complete and now the electronic side begins. I'm totally lacking in the skills or language of electronics but I have scoured these forums in an attempt to educate myself and move my project along.
Would one of the electronic gurus here please look over my first attempt at a wiring schematic using HobbyCNC 23-305-DS8A steppers, AnTek power supply, Gecko 251's and a CNC4PC C10 break out board.
I would very much appreciate any comments or suggestions to make this assemblage of components a success.
Senna
Old 09-04-2009, 11:34 AM
bharbour is on a distinguished road
It looks workable to me. I did not check the motor wiring. You might consider a fuse or circuit breaker on the 50V DC power supply output to reduce drama/destruction in case of a slip with a screwdriver or a stray piece of swarf.
Good Luck,
BobH
Old 09-04-2009, 12:09 PM
Bubba's Avatar
Bubba is on a distinguished road
I notice "daisy chaining" of the output of the power supply to your first junction block. I understand you should run separate wires directly from the power supply to the appropriate point on the block.
Also, Mariss has repeatedly indicated that DC power switching is not a good practice and that includes fuses in this area. Put a fuse on the AC side and let it go at that.
Art
Old 09-04-2009, 09:10 PM
Senna's Avatar
Thanks for the suggestions... it's also been pointed out that the stepper wiring has the coils shorted. I'll need to investigate and modify.
Senna
Old 09-05-2009, 05:56 PM
Senna's Avatar
Due to a major oversight on my part it's been pointed out that the Gecko G251 drivers will not operate in a unipolar configuration which is how I have the schematic drawn. The HobbyCNC 23-305-DS8A steppers are 425oz/in 4.2A when wired in bipolar parallel so they would exceed the amp rating of the G251's which are 3.5A max. So... I'm told I will need to employ current limiting resistors of 3.48K to keep the Gecko's happy and that I will suffer a slight loss of torque.
Here's the revised schematic showing the bipolar parallel config...
Senna
need electrical schematic for controller an limit switches and estop markus_detroy General Electronics Discussion 1 05-06-2008 08:47 PM
first attempt corrie Musical Instrument Design & Construction 10 01-05-2008 08:22 PM
EP 1090 isel controller schematic tom1975 Benchtop Machines 0 09-01-2007 07:57 PM
My first attempt Caprirs Vectric 4 08-28-2006 02:27 AM
Where to find Schematic 1Axis Stepper controller (no software/PC) just manual switch? Calico General Electronics Discussion 9 01-02-2006 10:30 AM
