Old 08-20-2009, 04:05 AM
mykeyb's Avatar
mykeyb is on a distinguished road
Question NEED HELP
Hi to the world of cnc.
I have aquired 4 Fulling stepper motors (uni pol), What i would like to know is if they are fine to use with a 48v 2 amp reg power supply using PMinMO,s
diy 3 axis controller boards ect.
oops: forgot to give specs.
rated v =12v
current/phase 0.68amp
resis/phase = 17.7ohm
induct/phase = 30mH
holding trq kg-cm2 = 9
leads = 6
rotor inertia g-cm = 200
weight =0.95 kg
detent trq kg-cm =0.72
size of motor 56mm x56mm x 76mm
