Old 08-17-2009, 01:39 PM
CNCDevil is on a distinguished road
Transformer calculation
I'm going to build an unregulated PS for my new router. Even though I'm quite sure that this is correct, please confirm that the calculations are ok:
Transformer:
2/3 (bipolar) * 4 steppers * 6 A/ph = 16A
40VAC secondary * 16A = 640VA
The closest match in this range is a 625VA transformer.
Capacitor: (50Hz)
(100,000 * 16A) / (40*1,414) = 28,000 uF
4 (or more eyes) are always better than 2.
Old 08-18-2009, 03:18 PM
Read and lean!
I have read some papers concerning the ripple voltage, which is why the filter capacitor must be added. I conclude that the bigger the capacitor is, the better.
I can't get hands on any capacitors larger than 3300uF where I live, but I'll just put 10 in parallel.
There is actually no reason for writing this, but now the thread at least have a little value for others that seek info on this issue.
Old 08-18-2009, 04:04 PM
Al_The_Man's Avatar
A little known fact is that if you when you run close to the maximum current capacity of the supply, any increase in capacitor size requires an increase in transformer VA sizing.
Old 08-18-2009, 05:24 PM
Do you mean that the transformer power will decrease when using a capacitor larger than the calculated, when running close to max. rated amp?
Would you please explain why this is happening or give me a link to where I can read this stuff?
I guess you are saying that the best thing to do, is just keep the ripple voltage withing 10% of the rectified voltage. at max. amp. output of the transformer?
Old 08-18-2009, 08:31 PM
Al_The_Man's Avatar
Here is my divshare link, the pdf was too large to post.
http://www.divshare.com/download/8224888-77e
Old 08-18-2009, 08:51 PM
Nice document. I will probably need to read it trough a couple a times to get the hang of it, but it's definitely worth it.
Thanks so far Al
Need Help!- calculation biotec Stepper Motors and Drives 2 04-20-2009 01:26 AM
Need Help!- Deflection Calculation Freff DIY-CNC Router Table Machines 13 11-05-2008 07:40 PM
Is this calculation correct? h3ndrix Stepper Motors and Drives 4 02-07-2006 12:08 AM
resistor calculation need help mike10 Stepper Motors and Drives 2 03-29-2005 09:21 PM
Back EMF calculation? OCNC Stepper Motors and Drives 12 12-08-2004 10:03 AM
