I am converting a denford orac lathe, and i was wanting to use the existing wire loom that is connected to the stepper motors and limit switches. The problem is these wires are all in one loom, and not shielded... Will it be ok to use this wiring, or should i replace it with shielded wire? Thanx Adam |
| Just my 2cents. I am running some 4nm AC stepper motors with unshielded cable and when I tried to hook up some limit switches they would trip constantly even when the signal wire came within a several inches of the motor wire. I suggest shielded cable or at least run the signal and motor wires completely separate from each other. It may not be an issue with DC steppers though. testing will confirm. I am looking for some shielded wire at a descent price if anybody knows where to get some. |
| If so, this could be part of the reason, all parts of the system would be bonded together. Al.
| Wire EDM question | greenchair | EDM Machines | 1 | 06-25-2009 09:18 AM |
| Shielded wire for steppers, or not? | JanHenning | Gecko Drives | 19 | 03-08-2008 07:29 PM |
| Shielded wire where should I use it? | erkiwi | General Electronics Discussion | 1 | 02-21-2008 07:59 PM |
| Shielded versus not shielded cable.....? | REVCAM_Bob | General Electronics Discussion | 1 | 05-23-2007 07:55 AM |
| Source for shielded wire? | LeeWay | General Electronics Discussion | 7 | 03-11-2005 06:26 AM |
