Old 08-13-2009, 12:48 AM
sa1 sa1 is offline
sa1 is on a distinguished road
Power resistors,Pls help
What value of resistors would I use to limit the current to the steppers?
my specs:
Power supply: 24v 15amp
Motors: Nema 23 6-wire. 3.5v 1.4amp/ phase. 1.8deg. (3 axis)
According to my calculations:
3.5/1.4 = 2.5ohms (motor coil resistance).
Resistor
24v-3.5/1.4 = 14.64 ohms
1.4*1.4*14.64 = 28.69 watts (min.)
Is this correct?
Thks
Old 08-17-2009, 03:35 AM
Zig Zig is offline
Zig is on a distinguished road
Yes.
However You will need to make sure that the resistor while rated at the correct dissipation will not be glowing red hot while doing it.
Inother words .. at what surface temperature will the resitor be operating while dissipating the power.
Old 08-17-2009, 03:47 AM
sa1 sa1 is offline
Do different resistors operate at different temperatures?
If so, how will I know which one to use??
Old 08-17-2009, 04:01 AM
Zig Zig is offline
It is a game of specmanship.
In these days of miniaturisation some manufacturers specify their product to be able to dissipate a certain amount of power at a particular surface temperature.
The higher the temperature the more likely the component or its surounds will be affected and have shortened life.
You dont want to have components which might cause inadvertent failure of adjacent components ( say excessive temperature rise of an electrolytic capacitor) due to heat generated next to it.
So read up on the specs and select. You might be offered two 15 ohm 30W resistors. One will dissipate 30W and reach a temperature of say 50C the other might dissipate 30W and reach a temperature of 70C. Both will do it happily but one might have deleterious effect on the printed circuit board say.
Dont get fooled by specmanship.
Old 08-17-2009, 05:17 AM
sa1 sa1 is offline
Thanks Zig,
Now it makes sense. Just for information,, I plan to install the resistors on a separate board and have jumper wires connected from my controller card to the resistors. Also have a serious cooling fan blowing against these resistors.
In this way there is no heat what so ever directly on the driver board. The two PCB's are separate from one another, just the jumper connecting them.
..Now thats left is to find a supplier that actually specifies the operating temperature of their resistors...(ha,ha,ha).
Old 08-17-2009, 01:11 PM
pminmo's Avatar
pminmo is on a distinguished road
my specs:
Resistor
Is this correct?
Thks
Your calculations are correct. You will either need one or two per motor depending on drive method, wave drive can use one, two phase uses two.
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Light Bulb Inplace Of Power Resistors Khalid General Electronics Discussion 6 10-29-2007 10:46 AM
Question Power Resistors buddym Stepper Motors and Drives 1 11-07-2006 01:58 PM
Sensing Resistors vs Current limiting Resistors whitney Hobbycnc (Products) 3 11-05-2006 11:29 PM
Resistors!! How hot? southernexplore General Electronics Discussion 4 11-19-2005 09:32 AM
Power resistors in series tpworks General Electronics Discussion 14 04-27-2004 06:54 PM
