Old 08-12-2009, 10:23 AM
REVCAM_Bob is on a distinguished road
alternative to RFID
I need an alternative to RFID to i.d. a fixture and transfer that fixture identification to a computer...
thought about mulitple dowel pins sticking out of the fixture plate that could push against contact switches... (just as one option).... need maybe 1000 separate i.d.'s maximum.....
Anyone have any other ideas?
Thanks!
Old 08-12-2009, 10:40 AM
beege's Avatar
beege is on a distinguished road
bar code and reader?
Old 08-12-2009, 10:50 AM
Proximity detectors, small ones.
Mount them in an array of 3 by 4 and then have an aluminum block on the fixture that comes up close to this array. Bore holes in this block in line with the detectors you do not want to activate. Twelve detectors give you much more than 1000 ids so you possibly could use the spares for malfunction detection.
Old 08-12-2009, 03:54 PM
So use the proximity sensors like binary i.e. 64 32 16 8 4 2 1 etc... or is there a fancier way?
Old 08-12-2009, 04:10 PM
beege's Avatar
Maybe think along the lines of punched tape, like a parity bit, stop bit and data bits?
Old 08-12-2009, 04:21 PM
samco is on a distinguished road
Our K&T has a 'barcode' system iirc it has 12 rings that slide by 12 fingers to read the tool.
http://electronicsam.com/images/Kand...gerspindle.JPG
Old 08-12-2009, 04:24 PM
Al_The_Man's Avatar
I guess a little more has to be known about the environment, is there machining? Coolant? etc.
This will be a big deciding factor as to the sensing elements.
Old 08-12-2009, 07:45 PM
Something along those lines; 10 sensors give you 1024 discrete numbers.
I figure you can probably make the sensor mounting coolant proof by potting them in plastic with just the tips exposed. They could be inset into the baseplate with the blocks in the fixture; this way they are automatically cleaned off when things are cleaned to load the fixture and there are no moving parts. Also when the fixture is in use they are covered and protected from chips.
Old 08-13-2009, 03:22 PM
Al_The_Man's Avatar
Going this way is a viable solution as Geoff pointed out a method.
If you do use something like this, I would do a 'qualifying' check before the jig is loaded.
IOW, the code should read zero with no jig present, otherwise it could be a false trip/reading and could be set to cause an alarm.
Old 08-16-2009, 01:35 PM
thanks to all!
Yes, the possibility exists of metal chips etc.... hmmm maybe I need to think this through a little more....
  #11   Ban this user!
Old 08-16-2009, 02:22 PM
Like I suggested, put the sensors in the base and they will be cleaned of chips during loading of the fixture and protected by it when in use.
Alternative Material Jim Mill General Metalwork Discussion 5 12-30-2006 02:08 PM
Looking for an e-clip alternative. trilect Smithy 1 08-21-2006 09:18 PM
PIC Alternative Lston General Electronics Discussion 3 07-10-2006 02:35 PM
Alternative to Tormach? gpietersma Benchtop Machines 6 05-31-2006 09:54 PM
