Old 08-09-2009, 11:15 PM
WhistlePig is on a distinguished road
Wiring for joescnc x axis ?
In an many photos as I have seen I have always noticed two steppers and two leads screws for the X-axis, is there any special wiring when two steppers are driving two screws to help prevent lost steps ?
I have keling steppers 425/oz and the keling 4030 driver and I getting about 20 in/min jogs, much more than that and I get lost steps.
I am not seeing any real heat problems, and I am set to full step on a 3/4 * 10 pitch lead screw running 6 foot long. Seems to do a bit better on the y axis.
I most cases I am going to err on the side of torque, but was wondering if I should be seeing a bit more speed than I am getting ?
Thanks !
Old 08-10-2009, 10:26 AM
ger21's Avatar
Try 1/8 or 1/16 stepping. Full stepping is prone to resonance, which will cause lost steps. I'm assuming you mean 20ipm, and not 20 ft/min? The 10 TPI screws will severely limit your speed, but you should be able to get better than 20ipm. Most people use 2 or 4 turn/inch screws for more speed.
Old 08-10-2009, 05:22 PM
Thanks Gerry,
I will give it a shot.
In another thread I saw a raging debate on hooking two motors to a single driver, as I have done, would that (also) be an issue ? I do have an extra 4030 driver that I was saving for replacement/4th axis but if that will solve the problem so be it...
Thanks Again,
Old 08-10-2009, 05:43 PM
ger21's Avatar
That may cause a problem. I've read that two motors on one drive only works at lower rpm.
Old 08-10-2009, 09:14 PM
While I haven't tried the micro stepping yet (obviously I don't really need more steps per inch using a 10 pitch lead screw but I will give it a shot..), adding the other driver did bring me up to 48ipm with no load but no lost steps. I backed it off a bit and ran a job that seems to test the velocity a bit at 36ipm with little issue, a big improvement !
Thanks !
Old 08-11-2009, 08:09 AM
ger21's Avatar
Higher microstepping makes the motors run smoother, and reduces resonance which is a major cause of lost steps.
Need Help!- Four axis Controller Mach3 Configure+Wiring winattitude Controller & Computer Solutions 2 08-27-2009 02:12 AM
Best Wiring Layout For X & Y Axis? johnmac DIY-CNC Router Table Machines 0 07-22-2009 09:50 PM
Need Help!- Need Help with 4th Axis wiring X3 cncpilot Syil Products 7 07-07-2009 01:04 AM
4th axis wiring questions WGJ Haas Mills 8 05-06-2009 12:51 AM
Y axis connector wiring metalworkz Syil Products 4 05-27-2007 08:45 PM
