Old 08-09-2009, 07:56 PM
adbradley is on a distinguished road
Total NOOB needs advice on retrofit
I have a Denford Orac lathe that i have gutted all of the electronics from. i plan to replace the electronics with the following
Controller: http://www.kelinginc.net/C11Manual.pdf
Drivers: http://www.kelinginc.net/KL-8060.pdf
Here are the specs on the motors that came with the Orac
http://www.denfordata.com/bb/download/file.php?id=355 the motors are the 0310 A8
I picked up a couple 70vdc/4amp power supplies from ebay, so i have that covered.
I plan to use a VFD to control the spindle.
So what am i missing here? can someone review this stuff and give me some input?
Thanx,
Adam
Old 08-09-2009, 08:08 PM
jalessi's Avatar
jalessi is on a distinguished road
Thumbs up
Adam,
Looks like you have it covered.
Give us a shout if you get stuck.
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 08-09-2009, 08:11 PM
Do you know if there is a less costly board i could use? i dont really know or understand the difference between this one and just a basic BOB.
Old 08-09-2009, 11:06 PM
jalessi's Avatar
Post
Adam,
You could use a C-10 however if has no VFD provisions.
http://tinyurl.com/lvacsn
If you would like to control the VFD with Mach3 there are other options such as a C6 variable speed control board.
http://tinyurl.com/le7t8e
Its not a all in one solution however it will save you a few dollars.
Jeff...
Old 08-10-2009, 01:30 PM
would i still be able to use an e stop and proximity switches with that setup?
Old 08-10-2009, 01:55 PM
jalessi's Avatar
Post
Adam,
The C-10 has five input pins 10,11,12,13,15.
Pin ten is recommended for the eStop that leaves four inputs for home and limit switches.
Jeff...
Old 08-10-2009, 02:46 PM
I also notice the bigger board has a charge pump, do i need this?
Old 08-10-2009, 03:16 PM
jalessi's Avatar
Post
Adam,
The charge pump is a safety device that monitors Mach3, if Mach3 crashes or the computer stops running the charge pump relay will turn off whatever it is connected to.
Checkout the link below for more detailed information.
http://www.cnc4pc.com/Store/osc/prod...products_id=51
Jeff...
Old 08-10-2009, 03:41 PM
Al_The_Man's Avatar
Another name/method is a watchdog timer, I notice some BOB's use the W.D. method, it all depends on how the 12khz signal is used.
Some interpret it with a charge pump, some a timer.
With a WD, the 12khz signal keeps reseting the timer before it has chance to time out, if the signal disappears the timer timer times out and picks up a relay in the E-stop string.
Old 08-10-2009, 04:15 PM
Thanx Al, i will check that out as well, so far my money savings has been great through ebay.. i just picked up 2 gecko 203v's for $160 total shipped! so that on top of $80 for my two 70vdc power supplies, im at $240 for gecko drivers and decent power supplies!
now all i need is a BOB and i can get some steppers moving!
  #11   Ban this user!
Old 08-10-2009, 04:20 PM
My end result will be a mach3 controlled lathe with a VFD controlled spindle. Will it be worth it for me to pay $125 for the full c11 board or just get the c10 and add to it later?
  #12   Ban this user!
Old 08-13-2009, 05:54 PM
Can you guys review the stuff here http://www.cnczone.com/forums/showthread.php?t=87748 and let me know if im on the right track?
Total Lathe Noob CAD Advice Cartierusm General CAM Discussion 6 04-24-2009 12:12 AM
Total noob umarekawaru General CAM Discussion 4 12-18-2007 05:54 AM
total noob to g-code, pretty simple (i think) arc problem. RedSoxFox G-Code Programing 19 09-30-2007 07:41 AM
Hello, I'm a total noob unseen wombat Commercial CNC Wood Routers 5 01-06-2007 03:42 PM
Over the top easy question from total noob. GregoryA General Metalwork Discussion 4 10-01-2005 09:41 AM
