Old 02-27-2005, 09:06 AM
Mr Rob is on a distinguished road
Variable DC motor controller
As part of a college project i need to find circuit designs for a 48V DC motor, with variable speed aswell as forward/reverse. Could you point me to any such site or give ideas of your own, thanks.
Old 02-27-2005, 09:10 AM
ViperTX is on a distinguished road
Hmmmm...college project....think PWM....then google it. Check out Freescale, Siemens and take a gander at Microchip's website.
Old 02-27-2005, 10:26 AM
2muchstuff is on a distinguished road
I know that Vantec makes one and a whole series of others for radio controlled models. Otherwise try what Viper suggested. They are quite easy to build, basiclly a LM556 chip and a couple of high power mosfets for the output.
Old 03-02-2005, 10:18 AM
fly_champ is on a distinguished road
dc motor control
You are looking for a circuit called an H-bridge
it involves four transistors, probably fet's
how are you going to signal the motor for speed?
the most common way is to use PWM
if you have an old R/C servo with good electronics and stripped gears, you can make a cheap and easy motor controller with four FET's and a few resistors.
the servo will work with either a pwm signal or you can use the output pot to drive the motor.
parametric programming Karl_T CamSoft Products 21 05-24-2005 02:58 PM
variable speed dc drive DragnsBane General Electronics Discussion 5 02-08-2005 08:07 PM
Variable IO Numbers squarewave CamSoft Products 2 10-15-2004 02:42 PM
S/S Relays and Variable Speed Routers InventIt General Electronics Discussion 1 08-24-2004 12:05 PM
Variable Frequency Drives...how do they work? mastercnc General Electronics Discussion 4 05-27-2004 08:59 PM
