I have Built the Discrete Unipolar Stepper Driver Board And the 4 axis BOB that is posted in the open board section. My problem is I installed the polarised capacitors wrong (+ to Ground And - to Postive) and applied 12V DC Power to each. What kind of damage could I have done? Can I reverse the caps and be ok or are they trash. |
| Sometimes the smaller voltage ratings can be a bit more forgiving, if they did not get hot or show any outward signs you may be OK, I would remove them and put the proper 12vdc across them and monitor them for warm up etc. If the are high capacity, remove the power and put a high impedance VOM across them set to voltage range, there should be a slow decay of voltage to zero. Al
| jockey, Replace them, it isn't worth the hassle. They might work, might work for a while then fail, hard telling. If you have questions on the open source boards please post them on the open source controller board forum, that way others in the future can benefit form the question and answer. Phil
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| Series connecting PS caps? | jevs | General Electronics Discussion | 7 | 03-27-2005 10:20 PM |
| PSU & CAPs & Motor Questions.. | TTaki | Gecko Drives | 0 | 11-02-2004 09:43 PM |
| Whats wrong with this freaking rectifier part II | Noah | General Electronics Discussion | 19 | 07-08-2004 08:41 PM |
| Z Movements Are he Wrong Way. Why? | gopackgo | Kellyware CAM | 4 | 05-15-2004 06:10 PM |
| What is wrong with this freaking rectifier | Noah | General Electronics Discussion | 31 | 05-09-2004 08:47 PM |
