Old 08-05-2009, 08:50 AM
SPEEDRE is on a distinguished road
MPG and Momentary Switches?????
I have an salvaged MPG and want to use it in a console style scenario. Here's what I'd like to do. I'd like to connect the MPG to my BB and the use Momentary contact switches for the axis to move Can I just wire up the switches without any fancy electronics? Just the MPG and the switches and nothing else, like resistors or relays or processor chips. I am not electronically savy.
Old 08-05-2009, 08:55 AM
Al_The_Man's Avatar
Most MPG's are 5v TTL compatible output, two pulse channels, A&B 100 pulses/rev.
Old 08-05-2009, 03:27 PM
So, what does that mean ?. Can I use the momentary on switches just to assign axis movement?
Old 08-05-2009, 04:53 PM
ger21's Avatar
If you're using Mach3, then you should be able to. Mach3 has a button that toggles between the different axis for an MPG. You need to assign the switch to that button with an OEM Trigger.
Old 08-06-2009, 06:49 AM
So, if I made a configuration of six monentary's one for positive direction each axis and ditto for the negative direction how would that be wired to the BOB. What is an OEM trigger? Was'nt sure this made it thru read on to next text.
Old 08-06-2009, 06:55 AM
So, if I use one switch per axis(3) for positive movement and ditto for neg. movements(3) for a total of 6 switches, how would that be wired via BOB?. The MPG would handle the speed and the direction switches will handle the direction one axis at a time, or X & Y together?. What is an OEM trigger??
Old 08-06-2009, 10:24 AM
ger21's Avatar
You could use one switch total. The switch would toggle between the different axis. or you can use one switch per axis. As for direction, that's dictated by which way you turn the MPG.
OEM Triggers are used to let external switches activate functions in Mach3. You assign them to the input pins in the ports and pins screen.
Old 08-07-2009, 09:02 AM
I had no idea ! Wow, one switch to toggle directed by the MPG +, -, Fabulous. This is practically a pendant except it won't be hand held. Thanks ger21, this is all I've ever wanted to do, as far as right at the machine control goes. KUDOS ger21
Use of Momentary Switches on VFD db113 Phase Converters and VFD 11 10-11-2009 05:42 PM
Momentary Switch SPEEDRE General Electronics Discussion 3 08-06-2007 06:34 PM
Momentary Glitch or Glimpse of Great New Feature? Mike Nash Forum Questions or Problems 0 05-01-2007 08:19 PM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
