| If the Op amp input is across the resistor it will only see the volt drop, BUT if the 400v is referenced to ground at all then the op amp circuitry will have the same potential to ground. There is an opto isolator H11F1 that has a variable resistance output for voltage input, but if mv it may need boosting. I recall sometime ago reading about some analogue output devices that were fitted to Plasma supplies for AHC which were the same application. Al.
| Consider Norton current differencing op amp LM3900and its variants. The op map sits at ground potential whereas its inputs are tied via high impedances to the signal to be measured. Carefull selection of high value high voltage resistors in combination with lead lag compensation will allow you to happily set the input currents ( in the microamp region from memory ) into the inputs which are tied to ground at one Vbe drop. A different way of thinking about op amps. |
| Typically with the electronic driver modules the shunt is incorporated into the low side of the drive; that is the shunt is located between the motor and neutral or ground. This topology makes it relatively easy to monitor and sample current on a pulse by pulse basis. May be You ought to be a bit more specific about Your requirement. |
| I don't have a strict requirement. I am just in the experimenting stage. Is a normal op amp used on the low side? Is low side safer for the op amp/circuitry ? I am better at the coding then the analog circuitry so I am trying to wrap my head around it. Thanks Dave. |
| Well.. Yes and Yes but at he same time it depends. as in coding there are varoius ways of approaching a problem and various metrics ( big O say ) a coder may use to determine a better way NOT "the best" way. So it is in hardware. It is hard to respond in a meaning full way to the question what is THE BEST? I t depends. Often it is personal prefrence and experience.. Cost certainly plays a significant part in the design approach. So lets start with some basic issues. What is it you wish to implement? What voltage and what power rating? How do you want to control the "what it is you wish to implement" thing? Control strategies as already mentioned pulse by pulse, average? Control strategy: Current, voltage, torque, speed,..? I think having a more complete spec can only help to come up with "the best" selection of solution. |
| Look up some of the manuf app notes for PWM/Power FET output stages, they show examples of what you may be looking for, IR, FreeScale, Allegro are a few. Al.
#10
| For starters you could check the HexSense devices http://www.irf.com/technical-info/anarchive.html It has been a while since I visited these sites but also Motorola (Freescale) may have also. Al.
#12
| If you are not in love with the shunt resistor approach, Allegro makes some Hall effect (magnetic) current sensors that work with AC or DC, have very low voltage drop and the measurement output is isolated from the signal being measured: http://www.allegromicro.com/en/Produ...0758/index.asp I have not used these yet, so I don't know if they have any quirks, but they look ideal for this type of problem. Good Luck, BobH |
| Need Help!- looking for circuit diagram | kenshi | Bridgeport and Hardinge Mills | 14 | 08-02-2008 02:20 PM |
| led in circuit | graphpix | General Electronics Discussion | 5 | 12-27-2007 01:25 PM |
| R Shunt Burn | wanchai101 | Servo Motors and Drives | 0 | 03-26-2007 10:20 AM |
| Circuit Help | Shanghyd | General Electronics Discussion | 9 | 09-16-2005 08:02 AM |
| Circuit needed | jimini | DIY-CNC Router Table Machines | 5 | 09-04-2003 08:06 PM |
