Old 07-23-2009, 11:58 AM
idtkid's Avatar
idtkid is on a distinguished road
My machine's state power requirements aren't making sense to anyone
Just called TemCo, a company who sells phase converters. They too are confused by what my manual says, please can anyone help?
My machine takes 1 input of 3Phase power at 230V
It requires a 20 Amp slow blow fuse at the breaker \
It says it uses 28kVA / (items in question)
The spindle is 700W
I need a phase converter that will sufficiently power my machine. Any help would be greatly appreciated!
Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
Old 07-23-2009, 01:04 PM
Al_The_Man's Avatar
The maximum current at 230v 3 phase would be around 104amps for a 28kva supply.
Are you sure it is not 2.8kva?
Old 07-23-2009, 06:44 PM
idtkid's Avatar
First time kVA is mentioned in the manual it is 28kVA, next 2 times (found further in the manual) are 2,8 kVA. Ill assume the , is representing a . in this case. If this is true, ill bank on that because the previous breaker it was hooked up to was not 100 amps. Based on this new info what is my current draw?
Thanks Al for suggesting the 28 vs 2.8 as a possibility!!!
Old 07-23-2009, 06:52 PM
Al_The_Man's Avatar
European practice is to use comma for decimal point.
a 20 amp slo blow fuse should be ample.
It should draw no more than 10 to 12 amps.
Old 07-23-2009, 07:25 PM
idtkid's Avatar
I gotta keep reminding myself that everytime I get frustrated and something takes more than a day to figure out, ill learn alot of stuff along the way
Thanks BIG TIME for the help, I will be ordering the phase converter this eve
Newbie- Stepper power requirements stevestk Stepper Motors and Drives 1 05-18-2008 06:33 AM
Confused about power requirements Curtisbeef Stepper Motors and Drives 11 05-11-2008 12:50 AM
G203V Power Requirements Big John T Gecko Drives 3 10-10-2007 08:54 PM
2010 power requirements? Splint Servo Drives 1 06-26-2005 08:21 AM
Power Requirements CapnC General Electronics Discussion 4 12-29-2004 10:39 AM
