Is there a way of knowing the DC out put using a Toroidal transformer and a bridge rectifier? The Toroidal rating is 120vac input and 7VAC 10amp out put. Thanks 2nd ? Run 3phase 440V motors on 3PH 220V. Have not picked up the unit to see if perhaps it has internal 220V wiring options, but don't believe it does as the decal says 440V. EDIT: Ignore the motor ?, going to be hard to answer unless you know what exactly I have, when it is picked up and checked I'll ask then. Thanks again. Thanks again. Ken Last edited by Ken_Shea; 07-22-2009 at 09:50 PM. |
| Is there a way of knowing the DC out put using a Toroidal transformer and a bridge rectifier? The Toroidal rating is 120vac input and 7VAC 10amp out put. -------------------------------------------------------------- The bridge Rectifier Voltage output is the 7 Volt AC times the factor 1.414. The current capability will drop by a factor in proportion to the increase in output DC voltage. DC output voltage: 7 x 1.414 = 9.898 Volts DC Output Rough Output Current Calculation: AC wattage calc: 7 VAC times 10 Amps = 70 watts of power DC wattage rough calc: 70 Watts divided by 9.898 Volts DC = 7.072 Amps DC. after capacitor is added to circuit for filtering. Guess on Capacitor value 4700 uf @ 20 to 50 Volts DC. Hope this helps. Last edited by CJL5585; 07-22-2009 at 10:28 PM. Reason: Add filtering info. |
| In most cases 440v 3 phase motors are capable of switching to 220v. The only thing required is to increase the overloads to suit and check the current rating of any contactor and conductors. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 07-23-2009 at 11:03 AM. |
| You are correct Al, got it to the shop, while it is wired 440V it is also 220 volt capable. That was very good news! Found 2 metric reamers under neath the base, in excellent condition, along with numerous drills, many Allen head wrenches, dozens of smaller SHCS and 4 small taps ![]() The RPM range is 1000 to 7000, no power feed on any of the heads, no big deal on that at all, just would have been a nice extra. Now to get some power too it and hope the bearings are not trashed. Ken |
| Power Supply Advice | DonF | Benchtop Machines | 32 | 06-22-2009 10:27 PM |
| Power supply for stepper motor | gaga2410 | Stepper Motors and Drives | 7 | 11-08-2007 05:42 PM |
| Making a good use of Computer Power Supply 3.3, 5, 12, -12 Vdc. Advice needed!! | cjchands | General Electronics Discussion | 8 | 10-25-2006 06:45 AM |
| Step Motor DC Power Supply | BobWarfield | General Electronics Discussion | 9 | 09-18-2006 07:23 PM |
| help on stepper motor power supply | ahmed | Stepper Motors and Drives | 1 | 06-14-2005 11:56 AM |
