Old 07-17-2009, 01:22 PM
edsimmons is on a distinguished road
AC or DC
I'm fix this Shizuoka ST-N CNC knee mill and I'm not sure if it has an AC or DC motor.
We pulled off the old Shadow controller and added a MachMotion controller w stepper drivers, the guys at MM have helped a lot getting it set up and I've got all the axis jogging and running a few simple programs. The next step is to get the spindle turning. At 1st I assumed it was an AC motor so I was going to control it w a VFD but a Zone member mentioned it may be DC. Soooo.
Here are a few questions.
1) Dose this look like an AC or DC motor? The paint on the number plate is worn off so all I have is the # impressions.
2) If it is DC is there a DC equivalent of a VFD that I can control from my MM controller? If so can you post a link?
Thanks!
Ed
Old 07-17-2009, 02:35 PM
Al_The_Man's Avatar
The fact it looks like pole pieces bolted on from the outside has the appearance of DC?
If you take the terminal cover off and check the connections and/or check for brushes.
If it is DC and the present controller is no good, you could get a Baldor or KB SCR drive.
They come up on ebay all the time, but you will need the HP of the motor.
Old 07-17-2009, 05:38 PM
Oops, the 2nd pic should be this one.
Old 07-17-2009, 06:03 PM
The imprinted #'s on the plate look like this. The paint is gone but I could see these #'s
The numbers on the motor info plate look like this
SEN-15V 1.5
CONT 3500
A-H 170 J-K 180
A-H 12 J-K 0.33
6205 6306
77121 16
Ed
Al_The_Man's Avatar
DC!
Could be also wound field DC for that size and vintage, the SCR drives referred to earlier include wound field motors.
The SCR bank in the cabinet are probabally the old 3 phase SCR drive?
That looks like a fairly beefy motor, BTW.
Old 07-17-2009, 06:15 PM
Thanks Al.
Yes pic 3 is the old electronics, I'd like to ditch the old stuff and go with something more modern and controllable from my MM controller. Any ideas on which SCR would work well for my machine.
Ed
Old 07-17-2009, 06:21 PM
Al_The_Man's Avatar
You would have to come up with the HP or at least an educated guess, I would estimate 2hp if wound field.
If you go to the Baldor or KB site they will list the models.
Old 07-20-2009, 06:40 PM
Zig Zig is offline
Zig is on a distinguished road
The photo shows brushes.. but do they contact slip rings or comutators ?
Old 07-20-2009, 08:06 PM
samco is on a distinguished road
looks like comutators to me.
sam
Old 07-21-2009, 11:13 PM
jmelson is on a distinguished road
SEN-15V 1.5
CONT 3500
A-H 170 J-K 180
A-H 12 J-K 0.33
6205 6306
77121 16
Ed
Taking a wild guess at this, SEN might be "sensor", ie a tachometer with either 15 V / 1000 RPM or 15 V full scale.
Continuous RPM 3500
Armature, 170 V at 12 A = 2040 W = 2.7 Hp electrical input.
Field, 180 V at .33 A = 59 W, which sounds right where I'd expect it.
Jon
