Old 02-19-2005, 03:17 PM
johnt is on a distinguished road
another power supply question
I know there is a lot of discussion about supplies and you'd think I could sort through it all, but.......
I see a lot of reference to power supplies in the 5-6 amp range and this is whats causing some of my confusion.
If I have 4 motors, say 3 amps each, doesn't that force me to use a PS at least 12 amps?
Thanks,
John
Old 02-19-2005, 03:23 PM
ViperTX is on a distinguished road
If they are steppers and the 3 amps is for 2 phases....then 12 amps is fine....gives you some leeway....most people who use steppers would take the 12 amps x 2/3 and use that to find a supply. Remember that most have only 3 steppers....so, your current requirements for 4 motors is higher....did I confuse you?
Old 02-19-2005, 04:03 PM
Hi Viper, thanks for your reply.
I dont think you confused me...
Maybe I should explain my intentions.
I want to build a small plasma table. 4x5 ft
rack and pinion drive, with Y axis driven from both sides.
Eventually I want to have Z axis for torch height control.
Hence the 4 motors.
So.... if I understand you, I need approx 66% of my total motor amps to be delivered by my power supply. Right?
(I do remember reading that figure on gecko's site)
Thanks,
John
Power Supply Question BobLWeiss Stepper Motors and Drives 13 04-17-2005 02:27 PM
Power Supply ground question chas Gecko Drives 5 04-16-2005 06:48 AM
FNG Power Supply Question SteinAir DIY-CNC Router Table Machines 0 12-31-2004 09:31 PM
Yet another power supply question!! chas General Electronics Discussion 3 09-16-2004 11:49 PM
i got a power supply question ljoe1969 General Electronics Discussion 21 01-11-2004 11:19 PM
