| Just want someone to look over my numbers before I order. I have 3 stepers, 3v 3A each. All Identical. To start I'm building this board tachus42's 3 Channel Discrete Unipolar Baord. I am constructing a simple power supply with output at 32.5VDC 10amp. This board needs a chopper or resistors placed on each motor. According to my calculations I need: **7ohm & 63 watts MINIMUM.** First, is this correct? Second, the best resistors I found are at digi-key and are $11/pc. I need 2 in series on each stepper. Before I commit can someone check my numbers and confirm my selection? Link to 3ohm TEH70P3R00JE-ND And, of course, a 4ohm version in series. 5% tolerance at 70 watts puts me in the 63watt range nicely. I have been reading and learning so much this past month I think my brain has turned to JELLO! Thanks so much for anyone whom can help!!!! Last edited by JohnnyVegas; 07-13-2009 at 09:56 AM. |
| No. Your calculations are incorrect, you need basically 10 ohms at 90 watts. But I can't say that I would advise spending the money to do that. You will wind up with a full step driver that you won't get much speed from without resonating.
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
I purchased from HobbyCNC: Middle choice http://www.hobbycnc.com/products/stepper-motors/ #23-205-DS8 285oz-in bipolar rating, 205oz-in unipolar rating. 3v, 3A, 200 S/R, 2.2mH, Size #23, Dual Shaft, 8 wire FYI: I have not built the Power supply YET so I am still considering your other version you created. I did, how ever build the entire machine. The electronics are my final stage. These motors are to get me started. I am planing in the future to really upgrade these to more top of the line when I get over the CNC learning curve. |
| Thanks PMinMO. I went ahead and began building the 4 axis on your site with the PicSteps. I completed the 4 axis. Great design BTW. I tried to register for your website but it wont take my email. It's a hot mail account. Thanks for the help. Your website was/is a great resource. Here's a pic of the completed 4 AXIS I just built: |
| Really nice looking pcb! What did you use for silkscree/lettering process?
| Now that I see that it has worked I am going to try another idea on the PicStep board and try to refine it. |
#10
| I put some more pics and things on this thread http://www.cnczone.com/forums/showthread.php?t=86707 |
#11
| Here is another link to my newest screen process for my picstep boards: http://www.cnczone.com/forums/showthread.php?t=87333 |
| change of "check image" 0M and 0T | jeppes | Fanuc | 1 | 03-13-2009 01:34 AM |
| How to check "heartbeat" on BTC-1 computer? | Goslowjimbo | Bridgeport and Hardinge Mills | 7 | 06-14-2008 06:28 AM |
| V2XT error message "DRIVE FAULT detected (0,z,y,x) check log" | rfdoyle | Bridgeport and Hardinge Mills | 4 | 10-08-2007 03:35 PM |
| "pull up" resistors ? | boyvox | General Electronics Discussion | 9 | 06-22-2006 09:56 AM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
