From my surfing I have read that a PC router or Dremel uses a Universal Motor. As well I read a universal motor will run quieter, cooler from rectified AC line voltages(~90VDC). My goal is to use my new PC router with Mach3 and have the software control the RPM or the router. Does anyone know of a schematic or maybe a company that sells such a beast? Thanks for the help! |
| You most likely can run them off a SCR drive such as KB or Baldor Mains operated DC control , although I have never tried it, it would be interesting to know. You can get the open frame KB/Baldor much cheaper without the case switch and Pot, and build it in to your own cabinet. You can feed one of the PWM to analogue converters on a BOB to control it instead of a pot. Al.
| maybe you can try the low cost ac servo motor from www.dmm-tech.com |
| I remember all the motors I salvaged and just maybe I can find a stand-alone spindle that I can use one of these motors with. I have found some pages on DIY spindles but I almost need a mill/lathe to make one. I also have numerous pulleys of different sizes some with teeth and some without. ********************************************* 1 of these Globe Motors 537A250 Volts: 30.3 With encoder: HP HEDS-5505-G06. Pin 1 - Gnd Pin 2 - NC Pin 3 - ChA Pin 4 - Vcc (+5 VDC) Pin 5 - ChB The motor has a no-load speed of 3220 rpm @ 30 VDC The motor has a no-load current draw of 0.25 amps At 20 oz-in the motor runs at 2840 rpm and draws 1.95 amps ***************************************************** 1 of these Pittman 14203C361-R1 Came out of the same model of machine as the Globe above so I assume it has the same specs. ******************************************************** 1 of these. Hitachi Type: DCM-05A02-E1080 Volts: 36, Amps: 1.1 RPM: 2450 INS CL: B It also has an encoder. ******************************************************* 1 of these 403A472 Volts: 19.1 PN: C1160-85303 With Encoder. ******************************************************* 2 of these RS-540SH-32105 With encoder. ******************************************************* 6 of these Very specialized motors but I did find a web site where a fella had one working. COPAL PN: 12-60119-01 LBT79-002 Volts: 12.5VDC @ 2.5A PCB on motor has a MP6403. ********************************************************** 1 of these Johnson Electric DF651 (2) LG 120 VDC RPM: 9739 No other writing on it but I measured the physical dimensions and it is most likely the 001model. http://www.johnsonelectric.com/media...&IdProduct=552 I have seen similar motors used on spindles. cnconabudget and Wolfgang **************************************************************** I'm a pack rat, it drives my wife nutz... I will probably end up using my 9690LR Porter Cable but I would rather leave it in the router table and use something else. For the moment all I need is 1/8 bits for doing PCBs and once I get a few designs made I will look at some wood projects. And I ao have a Dremel... |
| Newbie- Universal Magnetics Servo Motors | Iron-Man | Servo Motors and Drives | 3 | 01-25-2009 02:46 PM |
| Quieter Dremel | chazmtu | DIY-CNC Router Table Machines | 2 | 04-18-2008 05:29 PM |
| What can I use instead of a dremel? | david90 | DIY-CNC Router Table Machines | 1 | 12-11-2007 01:50 AM |
| Universal and Stteper motors | Alex S.A | Servo Motors and Drives | 1 | 11-03-2007 08:57 PM |
| Dremel Based Wood Routers | Mhiran | DIY-CNC Router Table Machines | 5 | 11-08-2003 10:39 PM |
