Old 02-14-2005, 02:27 AM
itsme's Avatar
itsme is on a distinguished road
PCB soldering
Hi everyone,
I just ordered a Xylotex 4-axis Uipolar board kit which needs to be assembled.
Could someone please tell me what kind of solder is ideal. Is there any special solder needed for a PCB, or will normal electrical solder from my local hardware shop (B&Q...) work?
Warren
Old 02-14-2005, 09:35 AM
*Registered User*
wcarrothers is on a distinguished road
Make sure it is Standard 60/40 (that is the mix of tin and led although I don't know which one is which off the top of my head) solder Diameter 0.032" Thicker then that is harder to work with for small solder joints. Also a good solder iron with a small tip helps. I prefer conical tips (very small round point tips) vs screw driver tips but I do a lot of soldering. For years I used a weller iron with out one of those coil holders. After getting one I coulden't believe how much easier having an actual iron holder was. Also having a good small vice helpes a lot. I have a small one with plastic jaws.
But the point is if your solder is 50/50 or some other ratio it is not good for electronics.
Course you are in the UK else I'd say just head down to your local radio shack.
www.watchdogflyball.com
b/
Old 02-14-2005, 06:03 PM
scottsss is on a distinguished road
I bought the Xylotec board. Belive I did everything with crip connectors. No problems no complants so far.
Old 02-16-2005, 10:44 AM
Swede's Avatar
Swede is on a distinguished road
Warren I'm quite sure you understand this but for others who may be browsing... be sure your solder is Rosin fluxed, not acid fluxed. Most of the solders you'll find at home improvement stores, unless they are specifically for electronics, will be acid fluxed. They are used for plumbing and mechanical connections.
Having trouble cutting aluminum sheet fastturbovet General Metalwork Discussion 40 06-14-2005 10:33 PM
PCB manufacture skippy General Electronics Discussion 37 04-13-2005 11:05 PM
Soldering irons for PCB work OCNC General Electronics Discussion 11 11-24-2004 07:48 AM
PCB manufacture skippy General Electronics Discussion 3 10-13-2004 08:01 PM
Multimeter and soldering iron shopping. Konstantin General Electronics Discussion 3 08-26-2004 09:03 AM
