Old 06-21-2009, 07:58 PM
BWay is on a distinguished road
Using a Computer Power Supply for 5V?
I am putting together a CNC router and am using a server computer case for my control enclosure (Servo drives, Breakout board, & DC power supplies). Originally I was hoping to use the computer case power supply to run the cooling fans and a 5V for my breakout board. What is the easiest way to accomplish this? Will the power supply run ok without being connected to a motherboard? The power suppy is a ATX style.
Thanks!
Old 06-21-2009, 08:12 PM
idtkid's Avatar
idtkid is on a distinguished road
Yep, power supply will run fine. A simple voltage meter reading of the red and black wire pairs should provide you with more than enough 5V connections for fans and a B.O.B.
Just something to think about, a spare/old cellphone charger that outputs 5V may prove to be a smaller, quicker, simpler solution?
Rockcliff PE/Aluminum Router > 4'x8' CNC Router/Plasma > Manual DRO/CNC X2 > 4 Axis Syil SX3 and an Emco PC Mill 125
Old 06-21-2009, 08:17 PM
LeeWay's Avatar
LeeWay is on a distinguished road
Isn't there something you have to jumper or modify to use a PC PS as a stand alone source?
Lee
Old 06-21-2009, 08:22 PM
jalessi's Avatar
jalessi is on a distinguished road
Post
BWay,
Grounding the green wire (pin 14) will turn the power supply on.
Hope this helps,
Jeff...
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
Old 06-21-2009, 09:51 PM
Eurisko is on a distinguished road
+5V is always available at pin 9 ( +5VSB, purple wire ) when AC is applied.
This line is a standby line for general motherboard functions.
This output is limited to about 2 amps of current. Would be good for a microcontroller circuit or a BOB, but I wouldn't use it to run the fans.
Diplomacy is the art of saying "Nice doggie" until you can find a rock. - Will Rogers
Old 06-22-2009, 09:51 AM
I had thought about this but since the power supply came mounted in the case with wires ready to use it just seems too easy. (Famous last words!)
I tried turning the power supply on by shorting pin 14 to the ground. This seems to turn the power supply on for a second but then it shuts off. Any thoughts?
Old 06-22-2009, 10:17 AM
CalG is on a distinguished road
Eurisco
The chart displayed in the post above indicates only 10ma available from Pin 9 5V. You indicate 2 Amps! Big difference. Have you more info on using this to supply a BOB?
Regards
Cal
Old 06-22-2009, 10:27 AM
Originally Posted by CalG View Post
Eurisco
Regards
Cal
Looking at my power supply the +5VSB output will supply .8A.
Old 06-22-2009, 10:30 AM
Al_The_Man's Avatar
The simplest access to 5v is off one of the 4 pin P.S. connectors, if is is a server supply the wattage capacity should nice and high.
Old 06-22-2009, 11:19 AM
jpardue is on a distinguished road
Thumbs up Converting a Computer Power Supply
There is a great Wiki article on exactly how to convert an ATX power supply. This is the power supply used in millions of computers, often free for the taking from junked machines.
I have built several of these for various projects. Of note, the Wiki design yields a Power ON indicator and switch and jacks for all the available Voltages. It uses a 10 Ohm, 10 Watt load resistor to keep the supply running. On several of mine I used a 12 Volt bulb in an automotive fixture as a load resistor, preserving all the 5 Volt Amperage for my project.
The common PC built since year 2000 will have a perhaps a 350 Watt power supply, which will deliver some impressive numbers:
+ 3.3 Volts at 20 Amps
+ 5 Volts at 25 Amps
+ 5 Volts Standby at 2 Amps
- 5 Volts at 0.5 Amps
+12 Volts at 12 Amps
-12 Volts at 0.6 Amps
A 1,000 Watt server power supply sports big 12 Volt Amps, but note the 5 Volt Amps available isn't much more than the smaller supply:
+ 3.3 Volts at 30 Amps
+ 5 Volts at 30 Amps
+12 Volts at 20 Amps (80 total Amps, 4 separate 20 Amp circuits)
-12 Volts at 0.3 Amps
The 5 Volts Standby is there to power a motherboard's circuits to sense the power ON switch and wakeup functions. This 2 Amps is there as long as the supply is getting AC power.
Every PC power supply I have worked with has a 110/220 Volt input selector switch, so they can be powered from either AC line Voltage.
Link to the article:
http://www.wikihow.com/Convert-a-Com...b-Power-Supply
Hope that helps,
Jon P.
Inventing: The Dreams Stuff is Made From
  #11   Ban this user!
Old 06-22-2009, 03:25 PM
Eurisco
Regards
Cal
Cal, the ATX specifications recommend that the +5VSB line provide 2 amps of current. The 10 mA mentioned in the chart has to be a typo. That's barely enough current to light an LED.
The only sure way to know how much current can be drawn is to check the specifications label on the power supply.
My ChiefMax 450W supply does indeed supply 2 amps at the +5VSB line.
  #12   Ban this user!
Old 06-22-2009, 03:45 PM
Originally Posted by BWay View Post
... I tried turning the power supply on by shorting pin 14 to the ground. This seems to turn the power supply on for a second but then it shuts off. Any thoughts?
Make sure that you're grounding the right wire (green, pin 14) and you have a tight connection. If the connection is good you either have a bad power supply or you're shorting the wrong wire to ground.
G320's and Power supply inside same box as computer?? Adamj12b Benchtop Machines 7 07-02-2008 11:32 AM
Computer Power Supply auvecu CNCzone Club House 13 07-24-2007 09:09 PM
Making a good use of Computer Power Supply 3.3, 5, 12, -12 Vdc. Advice needed!! cjchands General Electronics Discussion 8 10-25-2006 06:45 AM
Power Supply from a computer power supply jmytyk General Electronics Discussion 21 01-11-2006 02:56 PM
Computer power supplies flannman General Electronics Discussion 3 12-22-2004 10:45 AM
