My plasma cutter has a pot to adjust the power level. I'd like control this pot through the CNC control. The CNC control can ouput an analog voltage signal -10 to 10 V. Or, it can turn on outputs. Five outputs can be used to provide 32 levels (2 to the fifth). i have no experience with electronic device design. What sort of device would fill this need? Karl |
| Karl, CNC4PC makes a pot driven control board that would do what you want. http://www.cnc4pc.com/Store/osc/prod...roducts_id=179 Give Arturo a call: Arturo E. Duncan 1337 SW Sultan Dr. Port Saint Lucie, FL 34953 Phone:561-208-6664 Fax: 772-905-4387 email: aduncan@cnc4pc.com Hope this helps, Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| There may be a simpler approach, pot inputs can usually be substituted for a varying voltage between the common terminal and the pot slider input, you would have to check the voltage across the outer ends of the pot to find the max voltage seen at the slider input. There is a possibility to use an analogue input direct, or if the voltage required is larger than the analogue signal available, or it is not feasible to use a non-isolated approach, then maybe a OPTO IC such as H11F1 could be put to use. This OPTO accepts a varying voltage and the output simulates a varying resistance depending on voltage in. The input to the Opto may load the analogue signal up so a unity gain op amp may have to be used together with the H11F1. Al.
| I would think in this application it would be tricky, it is more suitable for processor or discrete logic control as it requires a known pulse train to control the wiper level. It also has no isolation if that is what is needed. Interesting chip though. Al.
http://www.fairchildsemi.com/ds/H1%2FH11F1M.pdf Looks to do exactly what I'm after. I'm using a galil card for the signal voltage. Galil calls these analog inputs but the host control has a way to set these as analog outputs. Don't know how its done, not seeing anything in the galil manuals. Anyway, do i need a unity gain op amp? More importantly what is this device and exactly how would i wire it? Karl |
Karl |
| I am away for the weekend, I will be back Tuesday. Did you check the voltage on the pot and does the unit show details of the pot input? Al.
| Karl |
| Need Help!- Computer to Control Comunication problem | JAnderson | Okuma | 4 | 05-21-2009 01:55 PM |
| Need Help!- Computer to machine help needed | Larry Myers | Controller & Computer Solutions | 3 | 08-21-2008 11:37 AM |
| Need computer to machine help | Larry Myers | Sharp CNC | 7 | 08-21-2008 11:31 AM |
| Howto control Vexta UDX5114 via computer?? | happytriger2000 | Stepper Motors and Drives | 22 | 04-19-2008 05:13 AM |
| VF-4 Control computer repeating characters | Drkk | Haas Mills | 5 | 11-02-2005 10:32 AM |
