Results 1 to 5 of 5
Thread: transformer hum
    kra
    kra is offline
    Dec 2004
    transformer hum
    I have built a 48 volt power supply that seems to work ok but it hums and vibrates a lot when I install an enclosure
    I have let it run for a couple of hours and everything seems ok
    (microwave transformer rewound with #14 magnet wire)
    Is there a way to controll this humming an vibration?
    (leaving the cover off helps but this holds the cooling fan)
    thanks,
    Randy
    Aug 2004
    That is one of the problems with unpotted (or unimpregnated) transformers. You could try potting it...or just mount it on rubber groumets.
    Jan 2005
    Missouri
    Is the cover made out of steel or aluminum? If steel, the transformer could have a strong enough magnetic field to cause the cover to resonate at 60 hz. Also could be a loose lamination in the core causing noise and the cover amplifies it.
    Dec 2003
    If it is a square laminated transformer, they usually are dipped and baked in shellac. Another way, if you have a MIG welder is to run a narrow bead across the laminations on either side, this is also a common practice by some manufacturers.
    Al
    kra
    kra is offline
    Dec 2004
    thanks for suggestions
    the core is welded across already and the housing is sheet steel
    also the core is shellacked
    i will try an aluminum cover and the rubber spacers
    thanks
    Randy
    1. How to wire a toroidal transformer..need advice
      By bgolash in forum General Electronics Discussion
      Last Post: 11-12-2007, 09:22 PM
    2. Microwave transformer built power supply
      By TinkerDJ in forum General Electronics Discussion
      Last Post: 08-13-2005, 07:19 AM
    3. 3 phase transformer on single phase?
      By jevs in forum General Electronics Discussion
      Last Post: 03-19-2005, 12:25 PM
    4. Connecting power transformer to 3 phase
      By keithorr in forum General Electronics Discussion
      Last Post: 12-17-2004, 02:52 AM
    5. 2KVA 220 to 110 transformer. Can it be used with 110 volt primary? And gantry pic
      By Bloy2004 in forum General Electronics Discussion
      Last Post: 06-29-2004, 09:28 AM
