Old 02-10-2005, 06:00 PM
wired is on a distinguished road
proximity sensors
Anyone know a good source for inductive proximity sensors like the ones used in Mach 2?. Thanks, John
Old 02-10-2005, 06:46 PM
trubleshtr is on a distinguished road
what size were you looking for? Omron makes them, actually there are tons of manufacteur's out there, have you tried ebay?
I might have a few I could sell depending on your needs/size ect...
menomana
Old 02-10-2005, 07:20 PM
I'm not sure which type would be best. I was thinking about using the barrel style,( 4 or 5 mm). My machine is very simular to the shopbot.
Old 02-10-2005, 09:00 PM
*Registered User*
wcarrothers is on a distinguished road
I get a lot of other sensor stuff from www.automationdirect.com I know they have a selection of proximity sensors. I have been ordering sensors from them for the past 3+ years.
b.
Old 09-30-2005, 02:12 AM
rnprasad is on a distinguished road
Can I get 0.2 mm sensing distance with any of the proximity sensors?
Old 09-30-2005, 08:47 AM
Al_The_Man's Avatar
Sensing range is dependent on diameter and wether or not shielded type, with the shielded type the metal barrel goes right up to the face, otherwise there is a plastic end which allows slightly more detection range.
Old 09-30-2005, 10:45 AM
tjstraz's Avatar
tjstraz is on a distinguished road
Jameco...
http://www.jameco.com/webapp/wcs/sto...egoryId=354040
I have been using the square green units for the past year with great success.
They are connected to a Soundlogic breakout board.
Tim
Old 09-30-2005, 11:29 AM
Evodyne's Avatar
Evodyne is on a distinguished road
Wired,
These can have different types of outputs and supply requirements. I've seen them with TTL compatible outputs, open-collector, etc. What are you wanting to tie them to? I guess maybe a better way to ask is what do the inputs your going to hook these to need/expect?
Lance
First CNC Machine georgebarr General Metal Working Machines 78 11-08-2009 11:35 PM
Inductive Proximity Sensors-what are they? Splint General Electronics Discussion 3 08-01-2004 05:24 PM
capacitive proximity sensors owhite General Electronics Discussion 7 03-16-2004 08:49 AM
Proximity switches bgriggs DIY-CNC Router Table Machines 5 09-01-2003 12:13 AM
proximity switches rcrabb DIY-CNC Router Table Machines 6 07-20-2003 11:27 PM
