Old 06-14-2009, 11:34 PM
parametric.ms is on a distinguished road
How to Observe IGBT QM30DY-H
I want to know how to check IGBT QM30DY in normal condition using Digital Multimeter?
What value should I use on DMM (Diode or Ohmmeter)?
C2E1 --- E2 ---- C1 ---- B1-E1 ---- E2-B2
between C2 (+) - E2 (-) =....... ohm ?
between C1 (+) - E1 (-) =....... ohm ?
etc
Thanks,
Andre
Old 06-16-2009, 11:27 PM
Gold Member
Mariss Freimanis is on a distinguished road
What are you trying to do? You are not very clear in your question. A good transistor (IGBT, MOSFET, bipolar) will read "open circuit" (100K or more with a multimeter) collector to emitter if it's an IGBT or bipolar device or drain to source if it's a MOSFET. A bad device will read 10 Ohms or less. Silicon (IGBTs, MOSFETs, bipolar NPN and PNP) invariably fails shorted.
Mariss
Old 12-30-2009, 10:25 PM
p27182's Avatar
p27182 is on a distinguished road
http://www.datasheetcatalog.org/data...on/mXutxyr.pdf
page 1 bottom right. that'd be your schematic with internal diodes indicated.
good stuff.
-pat
Need Help!- IGBT gate driver libbresse General Electronics Discussion 2 05-07-2009 09:14 AM
Powerex Intellimod IGBT as an H-Bridge geo01005 Servo Motors and Drives 0 03-23-2009 11:51 PM
Prices on IGBT CM150DY-12 lester1 General Electronics Discussion 0 02-17-2007 03:11 AM
