Old 06-13-2009, 10:00 PM
mmc005 is on a distinguished road
Compumill Conversion
I have an old Compumill 4000 with a Dynapath Delta 10 control on it. The control has a bad comm. board and I don't want to repair/replace the board due to the cost vs. capability of the control.
I want to pull that control off and replace it with a computer running Mach3 software. The machine has DC Servo motors with built in encoders, the motors are Baldors.
I know I need to replace the drives for the motors and have a breakout board for the computer, what else do I need to make this work?
I am looking at the Gecko G320 drives and the C11G interface card from CNC4PC.com. The instructions mention a power supply, do I need one? One for each drive or just one for all of the drives?
Any help with this would be greatly appriciated.
Thanks,
Dave
Old 06-13-2009, 11:18 PM
Matt Adams is on a distinguished road
Post
Dave,
Are the motors brush DC motors, or brushless motors?
If they're brush, you'll be fine. If they're brushless, you'll need to use a brushless servo drive.
You will need a power supply to power the drives. If you use the Gecko drive, you'll need a DC power supply that provides an appropriate amount of current that won't exceed what the three drives will use combined.
Matt
Matt Adams - Motion Control Application Engineer
IMAC Motion Control - Elgin, IL
Old 06-15-2009, 04:59 AM
Matt,
Thank you for your response, I'm 90% sure the motors are brushless but I will find out for sure today. I will also find out the combined current usage for the motors and the voltage used.
Thanks again,
Dave
Need Help!- Resurrection of a Hercus v300 Compumill UWA_FYP_CNC Benchtop Machines 14 05-24-2012 07:24 AM
Hercus V300 COMPUMILL DNC Jonathon Machine Problems, Solutions , Wireless DNC, serial port 4 11-04-2008 04:23 AM
Need Help!- Compumill 1500 CNC Vertical Mill - Computer problems rondawg333 General Metal Working Machines 6 09-06-2008 12:14 PM
Compumill With Dynapath 20 Cycle Start General Metal Working Machines 4 05-31-2007 12:43 PM
Compumill retrofit Dick L. Mach Mill 4 11-15-2006 05:07 AM
