Old 06-10-2009, 10:51 AM
machine_nut is on a distinguished road
Unhappy Serial port Help
I have a Hyundai 8S with A Hitrol 840C control (siemens)
Anyone out there know how to initalize the serial port on one of these machines? I know that there are parameters to set, etc. however the manual doesn't tell you much of anything about how to do that sort of thing...
I have set the comm settings & when I try to send or rcv an alarm comes up telling me that the device (serial 1) is not intialized.
Any help or even pointing me in the right direction would be welcome.
Old 06-10-2009, 12:29 PM
Matt Adams is on a distinguished road
Not sure if I understand what you're asking yet... are you saying you're not able to connect at all?
A quick back to basics thing to check is that you're using the right serial cable. Typically you'll need to use either a crossover DB-9 cable, with pins 2 to 3, 3 to 2 and 5 to 5. If this cable is that way, try using a straight through cable with pins 2 to 2, 3 to 3 and 5 to 5.
Otherwise, you'll need to double check the parity, baud rate, stop bit, etc and make sure that's all set.
Good luck!
Matt
Old 06-10-2009, 12:42 PM
underthetire is on a distinguished road
Is off, it would be a DB25. Null modem. pins 2-3,3-2,7-7. pin 4,5, jumpered, pin 6,8,20 jumpered.
Old 06-10-2009, 06:18 PM
Good luck!
Matt
Hi Matt,
Pretty much so,the alarm message from the machine is device (serial 1) is not initialized. Without being initialized you can't do anything, send or receive. When I put a tester on the rs232 25 pin connector of the machine all lites are red I thin some on the machine side anyway should be green, at least they are on any of my other machine I put the tester on.
Gene
Serial port to USB in VB.NET DennisCNC Visual Basic 1 12-07-2008 12:02 PM
serial port lamicron Computers and Networking 9 12-18-2007 10:42 AM
serial port+microcontroller visky General Electronics Discussion 1 10-28-2007 08:48 PM
USB to serial port stampman Machine Problems, Solutions , Wireless DNC, serial port 7 12-30-2006 01:17 PM
VK45 serial port TJ in CT Mazak, Mitsubishi, Mazatrol 16 11-07-2005 09:52 AM
