Results 1 to 7 of 7
Thread: POssible to Variable Speed of 2HP Motor?
    Mar 2005
    Argentina
    Hi guys, i have an 2HP / 220v AC motor and i want to lower the RPMs because are too high for my work. THe motor are running at 3000RPM, i want to controll the speed. Exsit some circuit that let me do that?
    Thanks in advance,
    Jul 2005
    If the motor is a standard induction motor the only way is with a Variable Frequency Drive (VFD) and running the motor on a frequency lower than the design frequency in which case you will also lose some power.
    Mar 2005
    Argentina
    Thanks, exist some VFD for 2HP motors? will cost too much? Im trying to design it. Hope someone can point me to some schematic.
    Apr 2009
    http://www.anaconsystems.com/text/opti_e2.html
    To control a single phase AC induction motor is very expensive and not sure if they go up to 2.0 HP. To control a 3 phase motor--$200-$300 for a VFD (variable frequency drive) and can be powered from 220VAC single phase.
    Dec 2003
    You did not mention if it was 1ph or 3ph, 1 phase split phase induction motors are hard to control speed wise as they tend to fall out of run at low rpm or especially when a load is applied.
    If you want 3 phase VFD design notes, I suggest you try some of the Semi manufacturers app notes, Freescale (motorola) Allegro, National Semi, etc.
    Mar 2005
    Argentina
    Quote Originally Posted by Al_The_Man View Post
    its 1 phase
    Dec 2003
    Quote Originally Posted by samsagaz View Post
    its 1 phase
    In that case, I would not even try.
    You are better off looking for a 3 phase motor or a DC brushed motor that you can control/build a mains operated SCR drive.
    1. Variable Speed
      By CoCoMedic in forum General Metal Working Machines
      Last Post: 09-23-2007, 11:11 PM
    2. Variable Speed Conversion
      By Cartierusm in forum Bridgeport and Hardinge Mills
      Last Post: 09-12-2007, 12:53 PM
    3. variable speed motor
      By Astroguy in forum Benchtop Machines
      Last Post: 05-25-2007, 06:13 PM
    4. Need help with Variable Speed Control for Bench Drill Motor
      By chola in forum General Electronics Discussion
      Last Post: 02-22-2007, 06:25 PM
    5. variable speed???
      By turmite in forum General Electronics Discussion
      Last Post: 03-27-2004, 02:26 PM
