| There are lots of power supply posts here in the Electronics and stepper sections that should give you a good start. Al
| Al, i have read many of the posts, but i thought it could be better to start one new discussion. I think i need a 1500VA transformer, a 34286uf capicator and a rectifier bridge over 70V and 30A, please correct me if i am wrong. I just want to know if i can connect two smaller transformers and what their vaules would be? |
| The AC secondary needs to be between 50 & 52vac allowing for the bridge drop, a 50,000µfd capacitor will give you 2.5% ripple, which at 70vdc will be 4.9v ripple on 60hz supply. Based on the calculated value of ac current (Iac= 1.8*Idc) your VA would be over 3.7Kva, but If your duty cycle is going to be low, I would tend to cut back on that figure. If the transformers are closely matched you can put them in parallel, take care to phase them correctly before connecting. The above calculations are based on 70v at a current of 30amps. Al
| Custom and cheap do not usually go together You would probabally be better off obtaing the separate items and building you own. You would have to find an electronic supply house that stock these kind of items.Al
| Connecting Two Power Supplies | Sanghera | General Electronics Discussion | 11 | 03-18-2005 06:03 PM |
| Computer power supplies | flannman | General Electronics Discussion | 3 | 12-22-2004 10:45 AM |
| 2 12volt power supplies in series | jderou | General Electronics Discussion | 5 | 09-03-2004 08:04 AM |
| These power supplies useful? | jlawren6 | General Electronics Discussion | 2 | 08-25-2004 08:19 PM |
| Lowering Voltage on Power Supplies? | DaSigntist | General Electronics Discussion | 2 | 01-17-2004 02:31 AM |
