Results 1 to 3 of 3
Thread: New Cap and 9x20 lathemotor still won't go high speed
    Feb 2006
    us
    This is the continuing saga of my 9x20 lathe motor replacement from 1/2 hp to 3/4.
    Well I upgraded the cap from a 40mfd 250vac to a 52-68mfd 220-280 vac(it was ranged like that). Now when I started it up I didn't have to spin the chuck to get it going on a medium speed.
    But as soon as I switched the belt to the higher speed(belt is also tighter on the pulley) it would trip the breaker.
    So do you think I need a bigger cap or what?
    Dec 2003
    What I don't understand is if you purchased a 3/4 hp motor is why didn't it already come with the Cap installed?
    Or at the very least the manufacturer or motor supplier should provide the size you require?
    Feb 2006
    us
    Oh did I mentioned I got it from Harbor Freight. I probably should just order the cap from them. A technician at Grizzly told me I need at least 60mfd 250 vac cap which I got one from an electrical place here in town. I was excited when I installed the new cap because it seemed to work better than the old one. Like I said I didn't have to spin the chuck to get the motor goin , until I switched the belt to the higher speed. Then the breaker blew again and again. So I'm kinda in the dark. Shouldn't a bigger cap give it the boost it needs? or then again I might have it wired wrong, I don't know.
  1. Add DIY high speed spindle?
    By bseibenick in forum General Metal Working Machines
    Last Post: 12-08-2009, 10:35 AM
  2. High speed motor
    By dfurlano in forum Benchtop Machines
    Last Post: 05-16-2009, 02:18 AM
  3. High speed belts?
    By jmkasunich in forum Linear and Rotary Motion
    Last Post: 04-16-2009, 09:49 AM
  4. High speed spindle... how high?
    By jonesja2 in forum General Metal Working Machines
    Last Post: 06-04-2007, 08:18 PM
  5. High Speed Spindle 10,000 to 40,000 rpm
    By whelen in forum Mechanical Calculations/Engineering Design
    Last Post: 09-05-2005, 09:42 AM
