Hi Guys, I picked up a used KBCC speed control, a nice, big unit which can handle 16 Amps DC output. While I was gloating, I noticed one of the components is shattered. It is a 600V rectifier, silicon, 25A, TO-220 package. Digikey does not have a direct replacement. My options are to go with either... 1) A 25A 400V device, or 2) A 20A 600V device I'm leaning towards option 1 to get the full, rated current, but perhaps option 2 would be a better choice for longevity, with a possible current derate. Any thoughts? Anyone else have a KBCC speed controller from KB Electronics? Swede |
| Howabout 35a 600v? ![]() http://www.allelectronics.com/cgi-bi...356&type=store here are my fav online electronics stores: allelectronics.com jameco.com mpja.com Jon.jon |
| Swede, The voltage rating for a diode should be the PIV or peak inverse voltage which is the max reverse voltage that will be present, If the voltages in the unit are not even close to 400vdc then there should be no problem. Obviously the max current is when the diode is conducting at that point the voltage is almost zero (across the diode), when the diode is non conducting the current is zero but the voltage can be maximum (reversed biased). If you have a rectifier with no smoothing the reverse voltage will be 1.4 x AC. With a smoothing capacitor after the rectifer then go 2x AC voltage rating. Al
Unless the rectifier is "shattered" because it was hit with a hammer, there is a good chance it exploded because of an overload. I would check the filter capacitors for short circuits before I fired it up. Ken
__________________ Kenneth Lerman 55 Main Street Newtown, CT 06470 |
| CNC Controlled Spindle motor speed control | gregmary | General Electronics Discussion | 13 | 02-27-2009 07:01 PM |
| Lathe Speed Control | CrazyRonny | General Metal Working Machines | 15 | 06-01-2008 09:57 PM |
| Problem with old GE 7542 control. | NcDave | Machine Problems, Solutions , Wireless DNC, serial port | 4 | 07-03-2005 09:41 PM |
| AC Speed Control | georgebarr | General Electronics Discussion | 7 | 01-06-2004 07:33 PM |
| Fanuc 18it Control problem | Wjman | Machine Problems, Solutions , Wireless DNC, serial port | 6 | 11-19-2003 12:41 AM |
