Old 05-29-2009, 12:39 PM
mrtank is on a distinguished road
Powersupply / capacitor sizing Help!
I have an electrocraft E240 servo I'm trying to drive with a Rutex 2010 drive
Motor specs
0.22 Nm Stall Torque
1.7 Nm Peak Torque
3.1 Amps Stall Current
24.5 Peak Current
4700 RPM Max Speed
48 VDC Max Voltage
1.1 kg Weight
4.5 kg Radial Load
2.3 kg Axial Load
7.8 v/kRPM Voltage Const
I figured I need a transformer of roughly 48*.7 = 33.6v is this correct?
if so what voltage capacitors do I need 48vdc?
thanks!
Old 05-29-2009, 11:37 PM
amplexus is on a distinguished road
Anything over 50 v should work but to be on the safe side go with more. I'd use a torroidal transformer, make sure you have enough current available. High current bridge rectifiers are cheap. As to filter cap size the formula is
(C = 80,000 * I / V). You are going to need some big caps.
Amplexus Ender
Bootstrap capacitor sizing legomanww General Electronics Discussion 1 04-06-2009 02:19 AM
Sizing a power supply smoothing capacitor Monte General Electronics Discussion 2 03-09-2008 10:12 AM
Powersupply CR250Greg General Electronics Discussion 10 07-20-2007 02:17 PM
can I use this powersupply? jimluu General Electronics Discussion 4 04-29-2007 10:05 PM
My Powersupply barkster General Electronics Discussion 6 04-12-2004 10:27 AM
