For my next project I'll be making a Jog Pendant with a very long cable. I'll have a handwheel, or MPG, on this pendant. All the ones I've used are just a single end encoder with A+ and B+ channels. I just went through painful episode where the trouble was traced to single end encoder on my lathe X axis. Don't want to take a chance on this issue here. Anyway, I noted going from single ended to differential on USdigital encoders involved adding a samll IC board right at the encoder. Cand the same thing be done for a MPG? How? Karl |
__________________ Warning: DIY CNC may cause extreme hair loss due to you pulling your hair out. |
| Would you double check my wiring? http://www.national.com/ds/DS/DS26LS31C.pdf pin16 +5volt pin8 ground pin1 mpg input A pin7 mpg input B pin2 A+ pin3 A- pin5 B+ pin6 B- The last four pins go on to a Galil 1900 ICM Karl P.S. edit, I must need to power the enable pins? |
| Looks good to me Carl. Since you are going to a differential input device, you will not need the decoder chip at the galil end. Depending on the encoder that you are using, you may need a capcitor or 2 right at the chip to smooth out the power going to the encoder. I have 2 different sizes on mine, I can find out exactly what they are if you need me to. As the encoder switches on and off it can cause large enough swings in the power going to the chip to cause it to go crazy, the caps will stop this. Mike
I will have to go outside and look to see what I used and verify the enable pin usage. Mike
| You should tie pin 4 high (5v) and pin 12 (com). ~10µf should suffice. See post #5 here http://www.cnczone.com/forums/showthread.php?t=8694 Al.
| differential vs. single-ended quadrature encoder? | postvmvs | General Electronics Discussion | 3 | 04-26-2008 06:28 PM |
| Differential Encoder Signals | eloid | DIY-CNC Router Table Machines | 8 | 01-29-2008 08:05 PM |
| differential encoder signal form | Karl_T | General Electronics Discussion | 1 | 03-19-2007 09:28 AM |
| Synchro Differential Gen ?? | Wannabe | General Electronics Discussion | 3 | 03-23-2004 06:36 PM |
| Optical Encoder Differential Line Driver | azsigns | General Electronics Discussion | 1 | 03-04-2004 03:41 AM |
