Old 01-30-2005, 10:05 AM
xairflyer's Avatar
xairflyer is on a distinguished road
Parrallel Port wiring
Is there any standard for how the parrallel port is wired.
e.g On some the x,y,z step are on pins 2,3,4 and dir on pins 6,7,8
others have x step on pin2 with x dir on pin3 and so on.
Also regarding the home and limit pins is this just all asigned by the software.
Old 01-30-2005, 10:48 AM
ger21's Avatar
Depends on the software. Some controllers don't let you change the pins. Usually the step and direction are consecutive. X step=2, X dir=3, something like that. With Most controllers, however, all the pins are assigned in the software.
I think that there are some limitations though. I think some pins can be output only and some can be input (limits and home) only. Not really sure, though.
Old 01-30-2005, 12:51 PM
pminmo's Avatar
pminmo is on a distinguished road
No standard, but seems a lot of the boards follow the EMC pinout at least partially. EMC doesn't have software pin configuration. Here is a table that I put together:
Phil
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 01-30-2005, 01:14 PM
Gold Member
JFettig is on a distinguished road
glad you asked, I was just gonna ask
Im going to be soldering right to the connector, do I only need 2,3 and 6,7 for x and z to hook directly? or do I need a ground somewhere? I should be running 5v off the computers power supply right, for gecko drives,
Jon
Old 01-30-2005, 03:21 PM
ViperTX is on a distinguished road
You will need a ground. You should use a separate power supply for the Geckos.
Old 01-30-2005, 03:29 PM
Gold Member
I am using a separate power supply to power them, but the common is 5v right? or is that a ground on the parallel port connector?
Jon
Old 01-30-2005, 03:41 PM
Jon
The common that everything (PC signals to Geckos) is referenced to should be ground and that ground is from the Parallel Port connector ground.
Old 01-30-2005, 04:07 PM
Gold Member
Oh ok, I just remembered seeing on my breakout board, 5v pin pin gnd for outputs from the breakout board and the diagram showed the 5v connected to the geckos and thats what I have been doing and it works.
Jon
Old 01-30-2005, 04:10 PM
sol sol is offline
Gold Member
sol is on a distinguished road
Which Geckos?!
"Common" is positive +5v from computer power supply on 320s...not parallel port ground.
Old 01-30-2005, 04:17 PM
Gold Member
G201s, yeah thats what I thought, is that for sure?
Jon
Old 01-30-2005, 04:35 PM
sol sol is offline
Gold Member
Yup
http://www.geckodrive.com/ycom/docum...EV4_MANUAL.pdf
http://www.geckodrive.com/ycom/docum...EV5_MANUAL.pdf
  #12   Ban this user!
Old 01-30-2005, 05:03 PM
Okay pin 10 of the Geckos is not a Common in electrical terms it is a common point for the anodes of the optical isolators which means that you have to supply +5 VDC from some source, +5 VDC is not available on the parallel port. My preference would be to have a +5VDC source where the Geckos reside and not draping a +5 VDC from your PC.
Parrallel port hookup joecnc2006 TurboCNC 1 02-16-2005 03:57 PM
Parallel Port Options JasonCroyle General Electronics Discussion 4 01-12-2005 07:23 AM
Wiring Question The Wizard General Electronics Discussion 17 01-04-2005 12:11 PM
Driving Parrallel Port JOE65 Mastercam 0 03-22-2004 11:16 AM
Using A Laptop Without Serial Port mtech Computers and Networking 6 08-17-2003 08:58 AM
