Old 05-21-2009, 08:38 PM
tony ennis's Avatar
tony ennis is on a distinguished road
Lathe lead screw block diagram, and a confession
The confession is that I don't have a clue what am doing. Figuring it out is half the fun, of course.
Block 1 is a 'pulse generator' attached to my lathe's spindle. This will likely be a disk full o' holes, an LED, and a phototransistor. The output is a stream of pulses directly related to the spindle revs.
Block 2 is a PLL that multiplies the frequency of the pulses from Block 1.
Block 3 is a virtual quick change gearbox. The input comes from the PLL. The VQCGB is nothing more than a multiplication and division of the input pulse frequency. The CPLD will be the main player here. Two switches - a 6PST and a 9PST - control the division parameters. The output is a pulse stream.
Block 4 is *something*. A stepper controller? This is where things get dicey in my brain. I have done the math up so block 3 is generating the right number of pulses assuming 200 pulses makes the stepper go around once.
Block 5 is the physical stepper and its power supply.
Would someone mind clearing up what the stepper controller in block 4 really is, how it relates to the motor, and how much of it I really need to worry about?
How does Block 4 relate to Mariss' CPLD tutorial project?
Thanks for the infoz!
Tags
controller, cpld, lathe, lead screw, stepper
Ron Steele's Mini Lathe CNC Conversion Lead Screw tetralite Linear and Rotary Motion 10 04-03-2010 07:21 AM
How do you mount a lead screw/lead nut? jbluetooth DIY-CNC Router Table Machines 2 12-01-2008 04:10 PM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
Block diagram for my cnc laser owhite Laser Engraving & Cutting Machines 0 03-10-2004 08:44 PM
