I want to be able to activate the coil of a relay with a photoelectric switch. The switch is 24VDC, 100ma load. The relay is also 24VDC, 1.5VA (1W) consumption. Am I correct in calculating that the relay has a draw of .04 amps and that the sensor will be able to drive this relay? Anything else I should be aware of? |
| DC power is IxV, VA is usually used to indicate AC power rating due to inductive effects. If the P.E. switch is 100ma max, then the coil on 24vdc requires a resistance of 240ohms or less, most manufacturers state coil resistance in the specs. Al.
| I don't see a ohm rating in the specs. Input circuit Supply voltage: 24V DC terminals A1(+)-A2 voltage selector engaged 24V AC terminals A1-A2 voltage selector engaged 110 to 240V AC terminals A1-A2 voltage selector not engaged Tolerance: 24V DC ±10% 24V AC -15% to +10% 110 to 240V AC -15% to +10% Rated frequency: 48 to 63Hz Rated consumption: 24V AC/DC 1.5VA (1W) 110V AC 2VA (1W) 230V AC 8VA (1.3W) Duration of operation: 100% Reset time: 100ms Residual ripple for DC: 10% Drop-out voltage: >30% of the supply voltage http://www.maxicont.hu/doc/termekek/...TA/en_d6dq.pdf Thanks for your help. |
| It would appear that the rated power consumption on DC is 1 watt so on 24vdc the current would ~42ma. Al.
| Put a heafty diode across the coil (A1 A2) in reverse polarity or you may quickly kill the output of the photoswitch. The inductive kickback from the coil can be a very high voltage spike of opposite polariity to the supplied voltage. This is common practice. http://www.allaboutcircuits.com/vol_3/chpt_3/9.html Hope you read this in time. Steve |
| I would suspect that you may only need the back EMF diode if fitting an external relay as in the dotted line. As I imagine that if using the internal relay that would be taken care of? Al.
| The diagram appears to show the internal relay and contacts, there is a dotted line with S switch and a external relay to the R.H. side. Presumably to switch a heavier duty relay? (1VA A2-B1) If you use the external type a IN4001 should be OK. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 05-19-2009 at 09:02 AM. |
| limit switch- home switch | normd | CamSoft Products | 1 | 05-16-2008 06:56 PM |
| limit switch and home switch setup | Runner4404spd | General Electronics Discussion | 0 | 12-15-2005 07:58 AM |
| Is it possible to use the home switch as the limit switch as well? | Darc | Mach Software (ArtSoft software) | 2 | 10-23-2005 12:50 AM |
| Limit Switch / Home Switch in Software | Sanghera | General Electronics Discussion | 6 | 11-01-2004 05:58 PM |
