Old 05-10-2009, 08:32 PM
BMG BMG is offline
BMG is on a distinguished road
Battery powered hand drill motor for a cheap spindle?
I am presently considering the build of a small desktop mill using MDF as the foundation materials. THe mill will be used for cutting wood, plastic and maybe aluminum. IN the process of searching my junk boxes, I came across a gently used 12V Skill battery powered drill. The charger was lost long ago. After pulling it apart, I found a 60W 13500rpm (16.5K no load) DC motor. Model RS-550 PF
A google search turned up
http://www.kysanelectronics.com/Prod...?recordID=1429
with further information provided by Kysan Electronics at
My question is would this motor be useful as a motive source for a homade spindle?
Yes? or should I find a charger for the drill? One nice thing about this motor is it sells for $6.50 USD - nice and cheap should it burn out.
Brian G.
Old 05-10-2009, 08:57 PM
johnmac's Avatar
johnmac is on a distinguished road
A good cheap spindle motor to start out with is a Harbor Freight 1/4" trim router. I got one on sale for $20. While its not a Bosch Colt, not bad for the price.
John
Sharpening drill bits by hand widgitmaster Polls 234 05-25-2012 06:05 PM
Battery Powered CNC Geof Phase Converters and VFD 6 06-06-2009 09:33 AM
Battery powered "flaps" JetGirl Mechanical Calculations/Engineering Design 7 12-03-2008 11:17 AM
Hand ice drill kotten1 General Metalwork Discussion 5 07-15-2008 02:50 AM
Could you use an air powered die grinder as a spindle? fireball08 DIY-CNC Router Table Machines 4 03-05-2005 12:10 PM
