| Hi All, I am now nearing completion of my first cnc retrofit and have just finished tuning my rutex servo drives with the supplied PID tuning software. I have also done the tuning in mach3 and can move each axis by pressing the arrow keys on my keyboard. HOWEVER, I seem to have a massive noise problem because as soon as I enable the limit/estop inputs in mach3, with the servo drives powered up I get random 'trips' every few seconds making the system unuseable. I'm not really sure where to start in solving this one, so I was hoping some of you could give me some pointers to save me spending a lot of time/money fixing stuff that doesnt need to be fixed. My servo drives are Rutex R2020's and the limit/estop inputs are connected through the DB15 input to the rutex motherboard. None of it is optoisolated. I'm not currently using any shielded cable (the original bridgeport wiring did not use shielded calbe either) but between the control box and the motors, wires are run through earthed flexible metal conduit. Where my limit switches are connected to the rutex motherboard db15 input I have 10nf caps between each switch input and ground. Should I have one accross the input and output of the switch as well? I currently have no spindle wired up so this is not VFD related noise. Any help would be much aprechiated. Regards, Dom **Edit** I should probably also add here that my braking resistors are in an earthed metal box and I have tried using the mach 3 input debounce option with no real improvement.
__________________ Dom http://www.ukrobotics.com/projects |
| Here is some recent posts on the subject you may want to look over. http://www.cnczone.com/forums/showthread.php?t=71923 http://www.cnczone.com/forums/showthread.php?t=79908 http://www.cnczone.com/forums/showth...t=56869&page=2 Al.
| Encoders are US Digital, E5 type. Al, thanks for the links - some useful stuff there. I sent a copy of this post to Tom at Rutex shortly after posting it here and he came up with an interesting explaination.
| FYI, here is a page where I keep a lot of tips on getting rid of noise in your CNC system: http://www.cnccookbook.com/CCCNCNoise.html Cheers, BW |
| Bob, thanks for the link I've printed that out for future reference. For a minute I saw the tin foil office and though it was just a piss take :P Al, Reading your other posts; are you suggesting one should common all their digital grounds (0v) together but keep them separate from analouge ground (earth) or are you saying that all the digital grounds should be commoned together and connected to analoug ground?
| I connect all mine to a central ground plate, together with the service ground conductor. See the first link MikeF OP. Your PC 5v logic is most likely already at the same earth ground potential as your 120/240vac supply anyway. Bonding them at a central point avoids ground loops. It depends on which method you select. (try) to isolate all or make all common. Al.
__________________ CNC, Mechatronics Integration and Machine Design. “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. Last edited by Al_The_Man; 05-07-2009 at 09:20 AM. |
| Advice needed. | tomshep | Benchtop Machines | 4 | 10-01-2008 04:59 PM |
| advice needed / to buy or not??? | teamjnz | General Metal Working Machines | 13 | 08-27-2008 08:48 AM |
| problems with EM/HF noise, anyone? | anthony | CNC Plasma and Waterjet Machines | 3 | 06-21-2006 08:49 PM |
| advice needed | trubleshtr | General Electronics Discussion | 32 | 04-21-2005 08:48 PM |
| Little advice needed | STUG | DIY-CNC Router Table Machines | 1 | 01-25-2005 07:11 PM |
