Hi all, I'm looking for your help to select a motor for my mill, it's an old Harrison http://www.lathes.co.uk/harrisonmiller/index.html I will be using the vertical head. What I want to do to start is run the machine as is for now but I only have a 240Vac 13amp supply. In the future I want to add variable/computer controlled speed adjustment and more power at a bit higher rpm. So I thought the easiest way to start would be to replace the 415v motor with a single phase 240v one. Like this one http://cgi.ebay.co.uk/Electric-Motor...1%7C240%3A1318 or this one http://cgi.ebay.co.uk/Electric-Motor...4.c0.m14.l1262 but while searching for motors I've noticed there are variables which course me confusion like: 1400rpm or 2800rpm Capacitors 3 phase or single phase Numerous phase inverters/converters So what do I do, single phase motor 2800rpm (saves me changing the pulley to give me the higher speed range); 2hp or 3hp (more power for a higher top rpm)? Or would this be the wrong route to add variable speed latter? So what's the right way to do this? All/any help is very much appreciated as always. ![]() John |
| A dilemma mate! I had similar choices a while back and replaced the 1ph 1.5HP 1400RPM motor with a 3HP 2800RPM unit and a 3KW phase inverter £130 for the motor and £179 for the phase converter (Drives Direct in Nottingham) Would I go for fixed speed ever again? not on your nelly! The phase inverter runs to 200HZ+ which would no doubt destroy the machine Simple to install and for 8mths it's been 100% reliable.
__________________ Keith |
| Hi Kipper, I've been looking at their listings on Ebay and considered contacting them for info but worried about them giving me the best advice over making a sale so thought I would ask here first. Is your drive controllable via Mach3 for variable speed or am I missing something? John |
The drive is programmable for ramping up/braking and way too many things Give em a ring...nice people!
LOL ![]() I understand where your coming from there as I will probably be mostly using the top speed only for Aluminium work and why I could cope without variable speed for now. John |
| John |
| Inverters for single phase motors are not common, expensive, and complicated, that's why I would go 3 phase if you plan on controlling it from Mach3. VFD's for 3 phase motors are commonly used in industry, and built to last, as are the motors. I believe that 3 phase motors are also more efficient than single phase. Paul |
John |
#10
#11
| Capacitors are used on 1 phase motors to set them into rotation in the correct direction. 1 phase motors on a variable frequency drive will drop out of run quite easily if under load at low rpm. It hasn't been mentioned that you can get 3 phase out with 1 phase 240v in on a VFD. I would go with a 4 pole motor, this allows doubling the Hz up to around 120Hz for both UK and N.A. This effectively doubles the base speed of the motor. Al.
#12
| So why not go with a 2 pole motor which is double the speed in the first place? Does anyone have a good link to an informative website about electric motors; I need more basic understanding I think ?John |
| Replacement motor for IH mill | c6vette | Industrial Hobbies (Support forum) | 7 | 04-24-2009 10:39 AM |
| upgrade motor for Micro mill? | phantomcow2 | General Metal Working Machines | 2 | 03-27-2007 02:44 PM |
| Motor Tuning for IH Mill | SMW Precision | Industrial Hobbies (Support forum) | 22 | 03-24-2007 10:12 PM |
| [B] Replacement Motor for Lathemaster Mill ZAY [/B] | bill south | Benchtop Machines | 4 | 03-01-2006 05:34 PM |
| IH mill motor upgrade | Randall | Industrial Hobbies (Support forum) | 13 | 11-14-2005 02:04 PM |
