Old 01-20-2005, 10:54 AM
runnoahrun is on a distinguished road
MOSFET swaping
If my current controller is rated at 6A per phase and I wanted to increase that to something like 15A could I swap out the MOSFETs for higher rated ones and put a better heat sink and fan on them? Or is there more to it than that?
Everybody starts at the bottom.
Old 01-20-2005, 11:33 AM
ViperTX is on a distinguished road
If the replacement MOSFETs have about the same gate characteristics then you should be able to exchange them. You also must make sure that you replace N Types with N Types and P Types with P Types. You may also run across the logic type FETs, so be aware. Also make sure that the package types (T0220, etc.) are the same or at least exchangeable (Things like Pin1 is Gate, Pin 2 is the Drain, etc.).
Old 01-20-2005, 12:38 PM
Al_The_Man's Avatar
The other thing maybe as the current will be quite a bit higher is check the wattage rating.
Al
Old 01-20-2005, 01:28 PM
H500 is on a distinguished road
The voltage must be equal or higher also. The circuit board traces might also need to be beefed up. The current sensing resistor might need to be higher watt.
Old 01-20-2005, 05:41 PM
*Registered*
ESjaavik is on a distinguished road
Yes, there is more to it than that. If you need to ask, you should not do it.
If you are able to design it from scratch, then redesigning may be an alternative to save you from making a PCB yourself. In an existing design you should even be careful changing to the same type from another manufacturer.
Avr Unipolar Chopper Drive H500 Open Source Controller Boards 26 01-08-2009 08:42 AM
