Sorry if this is the wrong section, but I thought it fit here better than any other electric sub forum. Now I got a sheldon lathe and it had a dayton motor. We had everything wired up and all it did was humming. It was wired for 220v and running on 220v. So then I played around a little because it seamed just like the starting capacitor was the problem. So I gave it a spin and it looked like it was starting and then it smoked up. Tried again with the same steps as before and it smoked up again. Now when I turn it on it makes no sounds. Did I burn the running capacitor just now too, or did I do something more serious like the windings. The fuses don't look blown, but I have nothing right now to test voltage or amps or anything going through to make sure they aren't. Thanks. |
| It sound like the motor is a burn out. If the start capacitor/start winding is not connected it will draw very heavy current. If smoke came out, it most likely needs a rewind. Was this a first time hook-up, or had it been running up to now? Al.
| It was a first time hook up. It looked more like it was coming from the capacitors though (the smoke) which is why I asked. How much do rewinds cost on !.5 horsepower motors. Just a range is needed unless I can find it out somewhere else. |
| For a Cap to smoke right off the bat would normally be because it was connected across the 220v supply, if it is a cap start only motor, if it has a centrifugal switch, generally if you give it a hard spin and immediately apply power it will go into normal run. Al.
| Yeah it has one. I already pressed it. It didn't trip though. Does anyone know why it would stop humming though. It would only be a reset switch or a fuse right? If the capacitors both burned and the wiring than those wouldn't stop the humming right? Thanks. |
| Do you have an Multimeter or some way of checking continuity across the windings, it is a bit unusual to go open, The run winding is across the supply so there is always resistance there which should be measurable, normally just a few ohms Al.
| I changed the fuse and put a new capacitor in. Got the motor wired up and now it works, but only in the forward direction. Before I draw any conclusions, is it possible to burn something on a capacitor induction motor so that it only goes forward. We tried a variety of different connections to get it go reverse, but we couldn't get it. Thanks. |
#10
| You have to reverse the start winding connections with respect to the run windings, this is the winding that is fed through the start capacitor. Al.
| motor tuning problem | m8kingit | Mach Mill | 3 | 04-28-2009 09:39 PM |
| Problem- Motor winding problem ? | iyerks | Servo Motors and Drives | 4 | 05-03-2008 08:26 PM |
| Mach 2 Motor Problem | djh82uk | Mach Mill | 7 | 09-25-2007 04:56 PM |
| motor problem | CNCadmin | DIY-CNC Router Table Machines | 0 | 12-07-2006 01:00 PM |
| motor problem | clammy23 | DIY-CNC Router Table Machines | 9 | 12-07-2006 04:30 AM |
