Old 04-23-2009, 09:41 PM
Hellpit is on a distinguished road
AC power issue Help Pls
In my installation, I am using a PowerOne MAP80 power supply for my 5 and 12 volts needs.
I am also running a 120V AC fan to cool the enclosure, as well as a large relay to control my bleed down resistor on my Servo power supply.
The problem I'm having is that when ever I turn the AC fan off, my PowerOne supply momentarly shuts off, then goes back on again. The same issue when I switch my relay on and off. I think the power supply is browning out.
I know that in a DC circuit you would normally install a flyback diode, but what do you do in an AC circuit? I pretty sure the fan is generating power back into my main AC supply, and same with the colapsing field of the relay.
Help?
Thanks.
Old 04-23-2009, 10:29 PM
Al_The_Man's Avatar
That is a switching supply so I imagine you are getting momentary pulse on the power line that is shutting it off, I would not have thought it would have been that sensitive.
An AC suppressor can either be a MOV Metal Oxide Varistor or a R/C snubber, the latter is usually used as it is easy to make up and is cheaper.
You need an AC rated cap, ~.1µf in series with 330ohm 1watt resistor.
Old 04-24-2009, 06:53 PM
Thanks Al, that is the direction I needed.
I'm also going to try re-wiring the fan and relays on double pole switchs to switch the hot and neutrals at the same time.
Old 04-24-2009, 08:32 PM
I built the RC snubber you described. Worked like a charm!
Thanks again.
R2V3 power up issue Boss 10 control wcarrothers1 Bridgeport and Hardinge Mills 1 05-18-2009 01:07 AM
4th axis power issue Legion99999 Syil Products 2 01-16-2008 12:48 PM
Power down issue. elaganis Haas Mills 20 06-27-2007 06:44 PM
Issue at low power.... WilliamD Laser Engraving & Cutting Machines 2 12-01-2006 11:44 PM
Series 1 Power Issue markhas Bridgeport and Hardinge Mills 5 08-10-2006 05:35 AM
