Old 04-16-2009, 09:06 AM
Adamj12b is on a distinguished road
How High can a motor be driven with VFD?
I am hooking up a VFD to an old Yaskawa servomotor to see if I will be able to use it as a spindle motor. The drive I am using is able to drive up to 1500Hz. My question is: How high is frequency can I go and still get power, And How will I know if I am too high? Will the motor stall like a stepper or anything? I know that most motors can be driven to 120 Hz.
-Adam
www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
Old 04-16-2009, 10:22 AM
Al_The_Man's Avatar
I have not had very good success with P.M. motors on a VFD.
The rpm depends on the top speed rating of the motor.
For example a 4 pole motor at 1500hz would be 7500 rpm.
Most brushless servo type motors are 6 ~ 8 pole.
The 120hz rating is usually considered max for a standard 4 pole induction motor.
You would be better off to get a Servo drive for it, what is the motor type?
BLDC or AC sinusoidal?
Old 04-16-2009, 10:29 AM
The motor is a Yaskawa USAMED-20 2.0kW 18.8A 1000RPM. It is an AC 3 phase servo, so im pritty sure its sinusoidal.
-Adam
High speed motor dfurlano Benchtop Machines 9 05-16-2009 01:18 AM
Low and high speed spindle motor cncor General Metal Working Machines 1 09-03-2008 10:23 PM
High Pitched Whine From VFD Driven Motor hamholfarm Phase Converters and VFD 3 07-22-2008 05:55 PM
High Torque , High Bandwidth Motor or Servo mastabib Benchtop Machines 0 09-26-2007 02:09 AM
