Old 04-15-2009, 12:04 PM
cjjonesarmory's Avatar
cjjonesarmory is on a distinguished road
Any Sources for Electronics Quick-Connectors?
I have a CNC Mill and I sometimes switch the milling heads out for different purposes. Really all I have to do is hook the head up to the hoist and remove two bolts, but the electrical connections are a pain!
There are three 250VAC 14 gauge wires running to the 2 HP motor, plus a few smaller 16-18 gauge wires for other purposes such as cooling fans, etc...
SO although I have lots of electrical and electronic experience, I don't know where I can buy quick-connectors. My motor is a variable speed AC motor hooked up to an inverter so I need some good tight quality connectors that will enable me to repeatedly connect/disconnect over the life of the machine.
Any suggestions for sources would be greatly appreciated. I would buy new if I can find them, and I had considered scavenging from old appliances, but it's hard to find multiples of the same connector to be used on multiple mill heads.
THANKS!
He is more machine now than man.....
Old 04-15-2009, 12:46 PM
Al_The_Man's Avatar
If you want industrial sealed disconnects, look at Hubbel, Brad-Harrison, Daniel Woodhead, they supply these connectors also with cords and moulded connectors.
If you can't find them online, go to any large Electrical Supplier wholesaler and check their catalogues.
Old 04-17-2009, 09:36 AM
Will do! Thanks for the info!
Need Help!- Quick Disconnect cable connectors? jeffmorris DIY-CNC Router Table Machines 20 05-19-2008 04:32 PM
Part sources for drive installation (BOB, connectors etc) Xerxes Granite Devices 2 04-21-2008 10:38 AM
Electronics Enclosure Sources? Chris64 General Electronics Discussion 2 12-20-2007 12:12 AM
Best type of quick connectors for motors? pfarber General Electronics Discussion 31 01-04-2007 04:43 PM
quick stepper electronics question keebler303 General Electronics Discussion 4 03-31-2006 07:40 PM
