Hi, i´m about to connect my xylotax to PowerSupply, but got some voltage problem. I have built PowerSupply as attached jpg, Without capacitor of 10000mF i´ve got 28V as expected, BUT when i also attache the capacitor i got 40Volt!! I´m not a rocket scientist and cant understand this, can anyone please help me to sort this out.... I guess i should have 28 V and capacitor... Best regards Rikard |
28 x .707. Al
| You say that there is an attached jpg, but I don't see it. If the transformer is rated for 28v AC you will get 1.414x28=39.6vdc when you rectify and filter it, as someone said above If you have some other setup, we would need to see it in order to figure out the problem. Al, didn't you show us how to add an inductor after the rectifier feeding the cap in order to cut down the peak voltage somewhat? |
http://www.cnczone.com/forums/showth...hlight=speaker Al
Without the capacitor your output voltage will vary between 0V and 28V*SQRT(2). Looking at it with a scope it will look like a sinewave where you cut out everything below 0V and turn it around to become positive. The RMS value of your waveform will be 28V. When you connect the capacitor, it will supply the voltage inbetween the peaks and get a recharge on each peak if there is a current draining it. So with no load you will have a constant DC equal to the peak voltage. If there is a load, it will look more like a dull saw form ramping up to peak, then falling slowly down to the next recharge 100 times / second. I hope your capacitor is rated for 50V, or I might hear it all the way over here. |
| Rikard, If you go to the Plitron Transformer site and look at the tech notes, it will explain all. http://www.plitron.com/ Al
| Thanks all! Then i guess 24 Volt is nearly to blw my card...24 x 1.414 = 33.93 Xylutex burns at 35 volt including backVoltage. I Guess the best thing i can do is go down to 18V and then get 25,452 V. Anyone of you using Xylotex? What Powervoltage does you use? Thank´s Rikard |
| Okuma LC-20 Threading problem | Gunner | Machine Problems, Solutions , Wireless DNC, serial port | 13 | 12-13-2011 10:11 PM |
| Beginner Troubleshooting and Building Considerations | coherent | FAQ of CNC Machine building | 3 | 11-10-2011 01:27 PM |
| Using Zener Diode for Control Voltage? | jevs | Servo Drives | 8 | 03-21-2005 10:48 PM |
| 5vdc from paralell port, not enough??? | thuffner3 | General Electronics Discussion | 8 | 11-23-2004 06:07 AM |
| How To; troubleshoot an Axis problem on Bridgeport BOSS | inthedark | Bridgeport and Hardinge Mills | 0 | 03-25-2004 07:35 AM |
